1967 Satellite Trim Question #142152
10/27/08 11:39 AM
10/27/08 11:39 AM
Anonymous OP
Anonymous OP
Could someone tell me how to remove the trim at the bottom of the windshield against the cowl? Also what is the easiest way to remove the remainder of the trim around the windshield and rear window?
Thanks,
Mike
Re: 1967 Satellite Trim Question #142153
10/27/08 03:22 PM
10/27/08 03:22 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
There is a specail tool for removing windshield trim. It is not unique to 67 Satellites. The end looks sort of like an arrow.
Re: 1967 Satellite Trim Question [Re: dynorad] #142154
10/27/08 09:21 PM
10/27/08 09:21 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It's best to have someone who knows how show you how its done so you don't damage the trim.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 1967 Satellite Trim Question [Re: Hemi_Joel] #142155
10/27/08 10:03 PM
10/27/08 10:03 PM
BFE
vancamp Offline
super street
vancamp  Offline
super street
BFE
And even with the correct tool sometimes there is 40 years of caulk/silicone holding the mouldings on. here is a pic of one kind of the trim tools
VanCamp Dent Systems Paintless Dent Repair/ Mopar Restification
Re: 1967 Satellite Trim Question [Re: vancamp] #142156
10/28/08 06:00 AM
10/28/08 06:00 AM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
Use the tool pictured above along with a heat source to warm the butyl sealer. A very hot summer day is ideal, but a heat gun will work also.
Heat the trim piece evenly along its length until very warm to the touch, maintain this temperature for 5-10 minutes to allow the butyl sealer to absorb the heat and become soft. Most times lower w/s trim needs to be removed this way to prevent bending and damage.
Extra time and patience spent here will prevent/offset time and effort spent on trying to straigten bent pieces.
Hope this helps.
