Eddy rpm heads and comp cam question #1421497
04/17/13 10:49 PM
04/17/13 10:49 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
I am looking at a set of edelbrock rpm heads. They come assembled at summit with springs. On edelbrocks website it says for use with hydraulic roller, but I have a solid roller 306b comp cam. As long as my cam does not exceed the lift of the spring rating on the heads will it matter if they are used with solid lroller vs hyd roller? The cost savings are great if I can get the eddy heads assembled with springs that work with my cam. Thanks
Re: Eddy rpm heads and comp cam question [Re: Tommy383] #1421498
04/17/13 11:07 PM
04/17/13 11:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
quickest way to destroy roller lifters is to little spring...
Re: Eddy rpm heads and comp cam question [Re: 1_WILD_RT] #1421499
04/17/13 11:38 PM
04/17/13 11:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
yep. You need to use the spring spec'd by the cam manuf. or someone who knows this stuff. The stock Eddy springs won't cut it on a solid roller. I use a Comp street solid roller and had to change them. It's more about closed and open pressures as well as coil bind than just about lift. Long story short....use the right spring!!
