need pix of 15x10 with 295/50/15 on D150 wide bed #1421473
04/17/13 08:24 PM
04/17/13 08:24 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
Anyone got pix of some 15x10 (with 4" backspacing) wheels with P295/50R15 on the rear of a D150 81-93 wide bed. I had some on a 81 Ram stepside & they were flush with the edge of the fenders & looked perfect, but not too sure about how they look on a wide bed, would they stick out?
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: 98RAM1500] #1421474
04/17/13 08:59 PM
04/17/13 08:59 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Yes they will.
These are 16x10 with 4" b.s.
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: 98RAM1500] #1421475
04/18/13 08:34 AM
04/18/13 08:34 AM
scratchnfotraction Offline
a 10" rim with 4.5 backset would be just right. my 10" rim with 3.75 backset stuck out just enuff to rubb the fender lip with a heavy load running 32x11.5x15 mudders.
with stock truck rear axle width,a 10" with 7.5 backset and tubb job you can stick a 29x15x15 M/T in the fenders on the wide box
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: scratchnfotraction] #1421476
04/18/13 06:21 PM
04/18/13 06:21 PM
Crockett ,TX
9
Crockett ,TX
yeah im probably leaning more toward 15x8's all around with P275/60R15 since it's a wide bed, but if i do get lucky enough to find a stepside bed then i'll go with the 15x10's on the back again like my last truck.
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: 98RAM1500] #1421477
04/18/13 07:37 PM
04/18/13 07:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
15 X 8s with 275/60/15s with 2.5" lowering shackles
I am truckless..
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: 98RAM1500] #1421478
04/18/13 09:23 PM
04/18/13 09:23 PM
I dont think there is a difference in the fender lip width from stepside to wide box.
my set up is exactly the same under ether one.
stepside
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: scratchnfotraction] #1421479
04/18/13 09:27 PM
04/18/13 09:27 PM
wide box
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: scratchnfotraction] #1421480
04/18/13 09:53 PM
04/18/13 09:53 PM
Crockett ,TX
9
Crockett ,TX
Well I thought I seen a 80's wide bed a long time ago with 15x10's & P295/50R15 and they stuck out alittle but on my stepside they were flush with the fender lip edge. The wheels I had on the stepside then have a 4 inch backspacing u can see in the pic that they look pretty flush with the fender
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: 98RAM1500] #1421481
04/18/13 11:03 PM
04/18/13 11:03 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
295 50 15 t/a on 15x10 .... looked a bit small in dia if you ask me
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: SANDYinNS Canada] #1421482
04/19/13 07:37 AM
04/19/13 07:37 AM
Crockett ,TX
9
Crockett ,TX
Thats the pic I was looking for, they do look small in diameter on a wide bed, im gonna go 60's all around and they are taller than the 50's, thatnks for the help guy & the pix
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: SANDYinNS Canada] #1421483
04/19/13 08:36 AM
04/19/13 08:36 AM
what backspace on those rims? they stick out like my 10" rim with 3.5 backset.
does look a little small for a truck, but a very nice truck on those wheels for sure.
Re: need pix of 15x10 with 295/50/15 on D150 wide bed [Re: 98RAM1500] #1421484
04/19/13 01:07 PM
04/19/13 01:07 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Part of the reason they look small is do to the height. This pic is a 195/75 on a 2wd. Now imagine the tuck sitting 4" higher because ridge Ran this size on the powerwagons stock. I ran 295/50s on 10" rims but mine were 3.25bs or something like that
