abody torsion bars #1421285
04/17/13 03:48 PM
04/17/13 03:48 PM
grande prairie , ab , canada
68notch Offline OP
68notch  Offline OP
hey guys , I ordered new torsion bars for my 68 barracuda , it still had the factory small block ones and its now got a 440 , so they came in they are the same on both ends while my factory ones are like half a turn out . I tried to use them but either the car is down on the ground with no suspention or its jammed in the air and rock solid . what am I missing ? thanks
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: abody torsion bars [Re: 68notch] #1421286
04/17/13 04:00 PM
04/17/13 04:00 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
Make sure you have them in the right sides as I believe what you describe can happen if that is not done...
Re: abody torsion bars [Re: 68notch] #1421287
04/17/13 04:11 PM
04/17/13 04:11 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I've gone from the factory 318 bars .87" IIRC up to 1.00" bars on my 68 Barracuda with no issues with ride height. Not to sound like a d__k but it sounds like there is and issue with the install. The bigger bars don't have the same offset the the smaller bars do, so you will need to back off the adjusters to get the ride height set properly. Really big bars don't have the offset at all. Where did you get the bars, and what size are they?
Re: abody torsion bars [Re: Skeptic] #1421288
04/17/13 04:28 PM
04/17/13 04:28 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Yep.
Bigger bars don't have the offset and also don't twist very much holding the car up. Jack the car up, loosen the front of the LCA to get it free, back out the adjuster real far, and tap the Tbar home. Then you can use the adjustment screw to hold the car up where you like it.
Re: abody torsion bars [Re: radar] #1421289
04/19/13 01:18 AM
04/19/13 01:18 AM
68notch Offline OP
68notch  Offline OP
hey guys , ya theyre 1 inch bars , when I install them I got no suspention with the adjuster cranked all the way up the car still lays on the ground , I pull the bars out and turn the key one spot and the car is at the top rock hard even with adjuster backed right off , its like I need something inbetween
Re: abody torsion bars [Re: 68notch] #1421290
04/19/13 10:22 PM
04/19/13 10:22 PM
IN
ahy Offline
ahy  Offline
IN
What make bars? There was a run of bars sold with unworkable hex "clocking". I don't remember the vendor name but if you post somebody will tag it.
I'm running 1" bars also and the installation process was exactly same as stock with plenty of adjustment.
Re: abody torsion bars [Re: 68notch] #1421291
04/19/13 11:04 PM
04/19/13 11:04 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Here's a pic that I took, it's the MP .920 bars side by side with the Just Suspension 1.00" bars, it's easy to see the hex offset. HTH, Steve
Re: abody torsion bars [Re: ahy] #1421292
04/23/13 01:28 PM
04/23/13 01:28 PM
68notch Offline OP
68notch  Offline OP
the bars are from PST and are 1.03 , thanks for the info , I will give it one more try , would it make any difference if I turned them end for end ?
Re: abody torsion bars [Re: 68notch] #1421293
04/23/13 02:13 PM
04/23/13 02:13 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes, there is a front and rear and should be info cast into them on the ends, or paint marks near the front like you show in the picture.
JB Rhinehart, Realist
A-Body's RULE!
