Re: windshield install - 71 plymouth B body
[Re: edp]
#1421273
04/18/13 09:03 PM
04/18/13 09:03 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
The blocks in the kit will work...You're basically centering the glass in the opening...Do a dry run and flip the blocks and/or trim them if needed..FYI some factory repop kits have metal centering tabs but you'll end up with the same rust issues you want to get away from... Also,You're linking the 3/8 kit everyone is recommending the 5/16 diameter kit.. And your guess is correct the primer promotes adhesion..You can buy it in a small can that has a applicator ball on the lid like a plastic PCV glue can has...Dip it in and run the channel with it...
[Re: edp]
#1421275
04/19/13 04:17 AM
04/19/13 04:17 AM
PasiR
I also wonder if the primer has anything to do with etching the painted surface for the butyl so adhere better?
Yep. I use always primer on both sides, frame and glass.
