windshield install - 71 plymouth B body #1421252
04/17/13 03:38 PM
04/17/13 03:38 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
are there any step by step video's of installing a windshield for a Satellite? Or pictures of one doing it themselves? also, I've gotten conflicting info as to whether or not a gasket as well as butyl is required for installation.
Just trying to figure out exactly what involved for both front & rear windows installation.
Thanks!
Evan
Re: windshield install - 71 plymouth B body [Re: edp] #1421253
04/17/13 04:35 PM
04/17/13 04:35 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
One other question - are the trim clips the same for the front & rear windows? Here's some Aveco clips - # 6003257, I think they're identical but not sure.....
Re: windshield install - 71 plymouth B body [Re: edp] #1421254
04/17/13 07:40 PM
04/17/13 07:40 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I've been trying to find out the same thing. But I know for sure there were no gaskets.The book says it was glued in.
Re: windshield install - 71 plymouth B body [Re: 71birdJ68] #1421255
04/17/13 07:56 PM
04/17/13 07:56 PM
Ont, Canada
gygeneral Online content
gygeneral  Online Content
Ont, Canada
I'm just putting in my glass, and this is what you use, butyl tape. I got mine at NAPA code PF411
http://www.proformproducts.com/en/products/info/?product=101&category=24
Re: windshield install - 71 plymouth B body [Re: gygeneral] #1421256
04/17/13 11:01 PM
04/17/13 11:01 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
But the book says it is supposed to be glued in and the back glass to.
Re: windshield install - 71 plymouth B body [Re: 71birdJ68] #1421257
04/17/13 11:59 PM
04/17/13 11:59 PM
Ont, Canada
Ont, Canada
You can ask a auto glass shop, but I'm positive you do not glue them in. It has to be flexible or the glass will break. Its not like modern windshields where they are engineered to be part of the structure.
Re: windshield install - 71 plymouth B body [Re: gygeneral] #1421258
04/18/13 01:17 AM
04/18/13 01:17 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
So I guess the factory service manual is lying when it says, "The front windshield and rear window are polysulfide adhesive sealed,(cemented-in) types". Section 7 page 1 in the 71 body service manual.Even has pictures.
Re: windshield install - 71 plymouth B body [Re: 71birdJ68] #1421259
04/18/13 04:49 AM
04/18/13 04:49 AM
P
PasiR Offline
PasiR  Offline
P
3M butyl tape is correct stuff for this job.
Re: windshield install - 71 plymouth B body [Re: PasiR] #1421260
04/18/13 07:29 AM
04/18/13 07:29 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
Pinch-Weld Primer might be a good idea prior to Butyl...
Re: windshield install - 71 plymouth B body [Re: scatcity] #1421261
04/18/13 07:53 AM
04/18/13 07:53 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I use 5/16" Butyl tape. No gasket. Has worked great for 35 years. Use the 2 rubber spacers at the bottom
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: windshield install - 71 plymouth B body [Re: moparmarks] #1421262
04/18/13 12:53 PM
04/18/13 12:53 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
so butyl it is, are those the correct clips for both front & rear windows as well & do the butyl strips usually come with the rubber standoff blocks ?
Good to know I was wrong on the 2 gaskets thing - do 70 & earlier b body's use a gasket vs. butyl? Maybe thats the confusion.....
thanks for the responses!
Re: windshield install - 71 plymouth B body [Re: edp] #1421263
04/18/13 01:08 PM
04/18/13 01:08 PM
moparmarks Offline
moparmarks  Offline
Yep those look like the corrct trim clips. Front and rear are the same.
No, Butyl does not come with the spacer blocks.
70 and older have the gasket.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: windshield install - 71 plymouth B body [Re: moparmarks] #1421264
04/18/13 01:37 PM
04/18/13 01:37 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
thanks Mark - hey a question for you, that dual exhaust hanger bracket plate I got from you has hump in it, not flat - is the flat one an E body deal only & B has the hump in it?
Thx. Evan
Re: windshield install - 71 plymouth B body [Re: edp] #1421265
04/18/13 01:44 PM
04/18/13 01:44 PM
moparmarks Offline
moparmarks  Offline
Thx. Evan
That must be so. The one I sent you was off of a 71 or 2 B.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: windshield install - 71 plymouth B body [Re: moparmarks] #1421266
04/18/13 01:44 PM
04/18/13 01:44 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
We have a 70 charger and 71 RR to do the windows eventually.
The one thing we need is the spacers for each. I know the 70 uses them on the rear, does the 71 use spacers for front and rear?
Can they be purchased or easily reproduced? Does anyone have the
dimensions.?
Thanks, Joe
Re: windshield install - 71 plymouth B body [Re: edp] #1421267
04/18/13 02:56 PM
04/18/13 02:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have a little experience with 71 E body. If I'm not mistaken my clips were different from front to back windows.
Back in 71 they used the butyle tape, which is like a adhesive.
Now they use urethane adhesive on new cars which is stronger because the glass is part of the structure of the car, I was told by the glass guy who installed my glass with urethane.
He did it back in 2006 and has held up well with no problems that I'm aware of.
I was told the urethane was better than the old tape stuff?
Re: windshield install - 71 plymouth B body [Re: Challenger 1] #1421268
04/18/13 03:37 PM
04/18/13 03:37 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Urethane will work fine. But if you are thinking about doing it yourself the butyl tape is easier - it's not as messy if you are not proficient with a urethane gun, plus it's more difficult get the right thickness with the urethane (you have to get the bead right and also not over-squash it down
Actually with the tape you are supposed to use a sealant around the edge anyway to ensure it is watertight (at least the Challenger is supposed to be that way so I assume same applies in your case.)
Anyway - I plan to use the tape.
Re: windshield install - 71 plymouth B body [Re: Gavin] #1421269
04/18/13 04:58 PM
04/18/13 04:58 PM
Cincinnati, Ohio
Cincinnati, Ohio
Urethane will work fine. But if you are thinking about doing it yourself the butyl tape is easier -it's not as messy if you are not proficient with a urethane gun, plus it's more difficult get the right thickness with the urethane (you have to get the bead right and also not over-squash it down
I understand the primer your suppose to use is a trade only type of product too, I was told.
The guy who did mine was in the car restoration business too he told me and he had a definite skill with the urethane gun.
Re: windshield install - 71 plymouth B body [Re: Gavin] #1421270
04/18/13 08:14 PM
04/18/13 08:14 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
We use the tape then fill around the perimeter with urethane calk like 3M's window weld...Seals the window in but will allow a little flex if needed...Ever try to get a window out when they used urethane only ??? Very tough if not impossible without damage and to be honest our old cars have alot of flex compared to the new cars...The original factory butyl tape had a cloth/mesh type backer to the inside so the trim{or you and your cleaning rag} would'nt stick fast...I've never run across this type in the aftermarket yet...
Re: windshield install - 71 plymouth B body [Re: screamindriver] #1421271
04/18/13 08:35 PM
04/18/13 08:35 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
heres a 3M product of Butyl tape with blocks, it doesn't state the block size, it'd be good to know what the OE block size was. Even if you couldn't buy blocks & presume you could make some out of hard rubber spacers. I'm guessing they're just stand off blocks for the glass from the window frame, that way the glass can''t slip down & bang into the body & crack.
Anyone know the size of those blocks?
here's the 3M stuff...
http://www.butyltape.org/3m-08612-window-weld-38-x-15-round-ribbon-sealer-kit/
