I want to install an oil cooler on my HEMI.
I am gonna run it with one of those oil cooler adaptors that install in between the oil pump body and the filter.
Does this one look like a good option?
http://www.summitracing.com/parts/bmm-70273or would I rather install something like this?
http://www.ebay.com/itm/181092566834?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649Im gonna mount it in front of the radiator....
I am afreaid the B&M unit might keep the oil a little "too cool" ???
Also, Im worried about oil drainback, which might cause dry starts....I was thinking about installing a switch to kill the coil so I can turn the engine a bit with the starter till the oil pressure is up, then start it.
Also, Im thinking that with the oil cooler on ebay I might have lesser issues regarding oil drainback and air getting trapped since its a single passage cooler? Also, it might be better so it doesnt cool the oil more than necessary?
Opinions????
***I am installing an oil cooler because my HEMI has a half fill of hard block, and seems its not cooling the oil efficently. Also, it went up to around 215°-220° after running for about 15 minutes at 2500 rpm during engine break in....water stayed at around 200°--->I decided to shut the engine down when I saw the oil reach that temp***
