pinion angle #1421085
04/16/13 10:59 PM
04/16/13 10:59 PM
jeff500 Offline OP
jeff500  Offline OP
Im setting up an 8 3/4 for my dakota to run street/strip,i lowered the rear of the truck 2 inches so how do i get the right pinion angle now?will lowering the rear 2 inches throw it out of whack or no?
Re: pinion angle [Re: jeff500] #1421086
04/16/13 11:12 PM
04/16/13 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it will increase the angle... you can do one of
2 things... put wedges in or cut the perches off
and re weld
Re: pinion angle [Re: MR_P_BODY] #1421087
04/16/13 11:32 PM
04/16/13 11:32 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
TWIG !!!!
You are wanted in this thread
Re: pinion angle [Re: MR_P_BODY] #1421088
04/16/13 11:51 PM
04/16/13 11:51 PM
jeff500 Offline OP
jeff500  Offline OP
The perches are not welded yet. I have the rearend sitting on the perches and bolted down,i read the articles and my understanding is line pinion up with trans,then rotate pinion down 4 deg and weld perches....just wanted to make sure im correct,thanks.
Re: pinion angle [Re: jeff500] #1421089
04/16/13 11:58 PM
04/16/13 11:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
yep... that'll work
