I use Mobil 85-140 lube in my 833 Mopar transmissions.When I put the Richmond in my car they recommend Red-Line lube in their transmissions They use standard T-10 syncro rings like any other design box.
It worked well when I had rings in it but when I converted it to Face-plate operation I put the Red-Line shock proof gear oil in it for racing purposes.
Gus
64 Plymouth Savoy
Dana 60
