Re: "high" compression 5.7 Gen 3 Hemi
[Re: CHAPPER]
#1420946
04/16/13 10:07 PM
04/16/13 10:07 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
Drag pack 5.7s are 12:1 or above.
I think Diamond, CP, and JE should all make pistons for that combination. They wont be cheap though, since they are an NHRA approved part.
Jerry - hemidup i think is his username can tell you alot more about this combination. he has a 5.7 engine in his challenger I believe.
They run a 2.100 chevy rod journal, and a 6.200 rod length. You can take a stock 6.1 crank and turn it down.
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: wldtm]
#1420947
04/16/13 10:15 PM
04/16/13 10:15 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I think if you bolt the eagle head to a stock 03-08 5.7 your close to 12 because of the chambers size differences
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1420948
04/17/13 11:07 AM
04/17/13 11:07 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
BINGO!!! Cheapest way IMO
