Winch install on car trailer #1420940
04/16/13 07:58 PM
04/16/13 07:58 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
I'm wanting to install a winch on my car trailer and wanted to know if you guys could post some pics and any info of wiring it up please. Thank you in advance.. Brett
Re: Winch install on car trailer [Re: 416scamp] #1420941
04/16/13 09:27 PM
04/16/13 09:27 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I have an S3500 Superwinch that I retrofitted with the external solenoid control so the winch control is self contained. For power I made up supply wiring, with clamps, long enough to reach the battery on the tow vehicle. I'm not sure what more would be of help.
Re: Winch install on car trailer [Re: 416scamp] #1420942
04/16/13 09:36 PM
04/16/13 09:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Don't laugh at my setup...lol.
I had this 1500# winch in the shop for a electric snow plow. So I bolted it to a pintle hook mount to see if it would pull a car. The mount weighs as much as the little winch. It can hold a much larger winch.
Stuck it in the receiver in the front bed of my trailer and it was plenty to pull a car onto the trailer, even better when I used a snatch block(2 lines)
I have done a lot of trailering and light weight is very important to me.
I stick this little setup in one of the storage doors on my RV and would use it if my car ever broke down and I couldn't drive it on. Works for me.
Wiring? Don't look at me, I drag a battery out of my RV and use alligator clips and the handheld switch that came with the winch.
Careful not to overload your tires with heavy equipment on your trailer.
Re: Winch install on car trailer [Re: Challenger 1] #1420943
04/17/13 02:14 AM
04/17/13 02:14 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
We used pick up alot of cars that have sat for 20,30,40 years or more
So to update from come along to winch (boat winches last a little while) we figured the winch & battery had to be hidden from the elements (both natural & criminal)
I built a custom tongue toolbox & put the winch,battery,straps,tools ETC in with a roller fairlead in it in the middle
I plugged the control in by either taillight on the back of the trailer (this makes it really easy for 1 man to load)
I used one of the extra terminals in the trailer to vehicle connector to keep the battery charged.
We used it for 8-10 years till some lowlife cut the chain out of the wheels & stole with a ball lock in place
Re: Winch install on car trailer [Re: 416scamp] #1420944
04/17/13 03:19 AM
04/17/13 03:19 AM
Make sure you don't use the winch as a car holder when towing It will tear the teeth up in the winch, don't ask me how I know I now make sure and back the winch up until the winch cable is laying on the floor of the trailer after I tie the car down with the four 5000 lb tie downs, one on each corner you will need to retighten the tie downs after thirty to fifty miles, the nylon straps will take a set and get a little looser Happy towing, be safe
