Lifter suggestions
#1420564
04/15/13 11:52 PM
04/15/13 11:52 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hey folks.
I was wondering which lifters people were using with hydraulic camshafts? I have heard some stuff about computer ones, so I thought I would ask the pros for suggestions.
Mike
1969 Dodge Dart Swinger
Re: Lifter suggestions
[Re: MikeyT]
#1420565
04/16/13 02:25 PM
04/16/13 02:25 PM
MikeyT
Watertown, WI
Oops, that was suppose to be Comp Cam lifters, not computer...
Sorry, anyway do people have any opinion on who makes the best lifter?
Mike
[Re: MikeyT]
#1420566
04/16/13 02:33 PM
04/16/13 02:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
No pro but I think the best are Schbeck(sp) but pricey... if you do the break in according to the directions and run the ones that come with the cam you SHOULDNT have any problems... run the zinc additive... coat the cam and lifters with the break in lube and take the inner spring out for the breakin
[Re: MikeyT]
#1420571
04/17/13 10:53 AM
04/17/13 10:53 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
If your talking about just standard conventional hydrualic lifters, hands down Hylift Johnson...there are some lifters on the market that are made offshore that are horrible. Many of the name brands in the USA are made by 2 or 3 manufacters and re-labeled or private labeled,
RIP Monte Smith
[Re: Crizila]
#1420573
04/17/13 03:51 PM
04/17/13 03:51 PM
CompWedgeEngines
Syracuse,NY
They are " special" indeed, but the Stock Eliminator guys are sure glad to have them. Another option is from Trend. Thye have basically for different version of a tool steel lifter available. STD Travel STD .904, low movement STD travel, oiling to face STD .904 low movement with oiling to face Those are their economy Premium style lifters ranging from about $16.00 to $24.00. They also offer Elite series ( CUP lifters) with other options from $34.00 each to $42.00 each ! Trend does a lot with NASCAR, and have some cool stuff. Contact me if I can help.
RIP Monte Smith
