Page 2 of 3 1 2 3
Re: Living with pump 91 with 10.2.1 BB [Re: Cab_Burge] #1420525
04/16/13 05:52 PM
04/16/13 05:52 PM
Nebraska
72Swinger Offline OP
Nebraska
What spark plugs are you running, brand and part #? I had a low compression(8.5 to 1 actaul) I/O drive boat motor that would ping using a Champion J12Y spark plug set but wouldn't ping using the next lower heat range, J11Y I would try the next colder heat range spark plugs The last iron headed 440 motor I tuned until it ping didn't like any total timing above 36 degrees on Oreogon non ethanol 91 octane pump swill I would put the total timing at 34 degrees revved up and readjust the intial to get between 14 and 18 BTDC I like and use really weak advance springs in my distributors so the total timing is all in by 2000 RPM My converters are a lot looser than that at WOT, they will flash to 4400 RPM or higher There very similar driving on the street to a stock Mopar 11 inch converter at light part throttle pressures below 3000 RPM also
I am using NGK xr5s and have been for years. This problem was non existent with the auto and loose vert. With the manual the engine is getting load now at 2-3000rpm and that's where the problem start raring its ugly head, that and pure pump swill. If I could just run 5 gallons of 110 per tank and not kill my o2 sensor, this thread wouldn't exist. When the weather let's up I'm gonna try to keep my initial as is,set total to 34-35 and swap out one spring for the next heavier. I have the black bushing left to narrow the advance down to I think 18 degrees total mechanical to try.
Mopar to the bone!!!
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420526
04/16/13 05:53 PM
04/16/13 05:53 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[I am using NGK xr5s and have been for years.
Arent XR5s the hottest plug NGK makes?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Living with pump 91 with 10.2.1 BB [Re: Von] #1420527
04/16/13 06:04 PM
04/16/13 06:04 PM
Nebraska
Nebraska
I'm not sure but I thought were recommended for 10.1 iron head big block.
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420528
04/16/13 06:10 PM
04/16/13 06:10 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
looking a t last dyno, 13.5 cruise 12.6 to 12.9 on throttle.160 t stat not good for street motor 180-195 is perfect.
Re: Living with pump 91 with 10.2.1 BB [Re: d-150] #1420529
04/16/13 06:23 PM
04/16/13 06:23 PM
Nebraska
Nebraska
Trying to keep this Big Block Dart at 160 degrees for 5 laps around a road course just isnt gonna happen. So ive accepted the fact that 180-190 is where its gonna be.
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420530
04/16/13 06:38 PM
04/16/13 06:38 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I'd go with the heaviest springs you can put in there total timing all in by 4200 you won't lose throttle response can you have the program fatting it up in those areas. Too bad you don’t have the full fast system and have it control the timing.
Re: Living with pump 91 with 10.2.1 BB [Re: JD Dart] #1420531
04/16/13 06:43 PM
04/16/13 06:43 PM
Nebraska
Nebraska
Yep I will do some experimenting and follow up what works.
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420532
04/16/13 07:17 PM
04/16/13 07:17 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
you can use e85 on the ezefi
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420533
04/16/13 07:18 PM
04/16/13 07:18 PM
Try putting a NGK plug number ending in -6,-7 and a -8 I blew out a Fel Pro PT head gasket, melted the 440 block and a M.W. iron head betwween the cylinders on #4 and #6 by swappping from a NGK-7 plug to a -6 at the track
Re: Living with pump 91 with 10.2.1 BB [Re: Cab_Burge] #1420534
04/16/13 07:23 PM
04/16/13 07:23 PM
Nebraska
Nebraska
What? Really? Damn so these are a hot plug then? SO a 5670-6 would be next colder then? Yeah im open to reduce the chances of head gasket failure lol!
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420535
04/16/13 07:24 PM
04/16/13 07:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a larger radiator in it... there is no reason you
cant keep it cool with a larger radiator and shroud
EDIT
I dont know the NGk numbers but if it is a hot one
you most likely will take care of all your problems
with a cooler plug... and maybe a touch more fuel
Re: Living with pump 91 with 10.2.1 BB [Re: MR_P_BODY] #1420536
04/16/13 08:33 PM
04/16/13 08:33 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
NGK numbers are backwards. The lower the number the hotter. 5 being the lowest and therefore the hottest...
Re: Living with pump 91 with 10.2.1 BB [Re: MR_P_BODY] #1420537
04/16/13 08:36 PM
04/16/13 08:36 PM
Nebraska
Nebraska
EDIT
Mr. P it has an excellent radiator already. I really appreciate you guys all jumping in here and helping out. Thanks a bunch! I just ordered a set of R5670-6 NGK's and when it warms back up im gonna get this thing dialed for pump piss and hope for the best.
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420538
04/20/13 09:49 PM
04/20/13 09:49 PM
Nebraska
Nebraska
Update. Changed plugs to the above NGK's and removed Silver bushing for the Black bushing. Replaced one light silver spring with one light blue. Set total timing to 35 and have about 17 intial. Huge difference! I get no ping in 2nd gear matting it at any RPM and just a tad if im lugging it in 3rd and tip in hard in the 1500 rpm range. I feel a bit of relief now that I dont feel like im ruining my engine whenever I drive it.
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420539
04/21/13 12:42 AM
04/21/13 12:42 AM
Buy some NGK -7 I ran them on the street with pump swill a lot leaner AFR than your using But it is a automatic with a loose converter and aluminum heads now
Re: Living with pump 91 with 10.2.1 BB [Re: Cab_Burge] #1420540
04/21/13 12:58 AM
04/21/13 12:58 AM
Nebraska
Nebraska
I may just do that Cab. Im betting that when it warms up and air density gets worse it may be fine?
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420541
04/21/13 03:23 AM
04/21/13 03:23 AM
The last 906 iron headed pump gas motor I had in my Duster would ping in the summer heat with high humidity, not so when it was cooler and dryer
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420542
04/21/13 09:58 AM
04/21/13 09:58 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
In theory that makes sense, but in practice it's usually backwards from that. The temperature is the biggest contributor to detonation, if you get the intake air temp down you can run more timing.
Re: Living with pump 91 with 10.2.1 BB [Re: Blusmbl] #1420543
04/21/13 11:16 AM
04/21/13 11:16 AM
Nebraska
Nebraska
Ok well I better get some even colder plugs to at least have just in case.
Re: Living with pump 91 with 10.2.1 BB [Re: 72Swinger] #1420544
04/21/13 02:01 PM
04/21/13 02:01 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I'm running 9.7:1 with a TQ50 Erson cam, flat top KB pistons that are out .009" (oops), ported 452 heads, headers and a torker II intake. All in a 5000lb 4x4. Running a stock distributor with the slots shortened up and the heavy spring removed and, if I remember correctly, 38 degrees total timing. So far I have had zero problems with detonation. Running NGK V-power 7 plugs. I am at 5000 feet in elevation though. I took it to Vegas but had fuel delivery problems so I wasn't exactly hammering on it. It is a 4spd so the load is similar. I do, on occasion, have issues with the plugs fouling slightly at extended low RPM, but they clear up quickly. And by low RPM I mean 600 RPM lugging because I'm too lazy to downshift. Don't know if any of that helps =). I have a set of Stage VI heads I'm porting that will end up on there eventually. Tight quench with a .045" gasket and .009" out should make for a detonation resistant setup in spite of the higher compression. Guess I'll find out.
Page 2 of 3 1 2 3
