Page 1 of 3 1 2 3
HEMI: Intake to Heads Oil Leak #1420295
04/15/13 02:43 PM
04/15/13 02:43 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi guys!
This is the 3rd time Im having to remove my intake because it keeps sucking oil from the Valley area into the intake ports and then into the chambers, fouling the plugs with oil after a few minutes of running time....
I have checked proper alignment, bolt interference with the intake bolt holes, etc....face of intake is parallel with heads....so its not that the faces are crooked and not sealing right one against the other, they are nice and parallel whenI shim them and then I check them with a gauge on all 4 corners.
I have glued the head side of the gasket to the head with silicone, and I have left the intake side of the gasket with NO silicone, just some grease....but its still sucking oil.
Im sick of this so Im just gonna silicone both side of the gasket to assure a tight leakproof seal.
Now, my other concern is the torque Im applying to the intake bolts.
Richard Nedball's book asks for 25 ft-lbs torque on these bolts....but it sure looks like a lot to me. Its just 1/4" bolts threading into ALUMINUM cylinder heads.
I have just tightened them with a small socket wrench till I felt they were were tight enough, didnt want to overtighten them and risk stripping threads on my brand new ALUMINUM heads!!
Should I just go ahead and torque them at 25 lbs-ft??? Is it safe to do so on aluminum heads? Still it sound like a lot for such a small fastener threading into aluminum.
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420296
04/15/13 03:06 PM
04/15/13 03:06 PM
Ohio
hemi-challenger Offline
Ohio
I would go back and re-read that part in book, it should be inch lbs not 25 lbs. Thanks / Gary
Re: HEMI: Intake to Heads Oil Leak [Re: hemi-challenger] #1420297
04/15/13 04:15 PM
04/15/13 04:15 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Ditto, re-read that. It's 72 in lbs on some and I think 48 in lbs on the others. Thats 4 ft lbs and 6 ft lbs!!! The proper intake torque and sequence is in the Mopar Hemi engine manual which should be on top of your work bench.
2011 Drag Pak Challenger
Re: HEMI: Intake to Heads Oil Leak [Re: rickseeman] #1420298
04/15/13 05:33 PM
04/15/13 05:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, I do have the MOPAR HEMI ENGINES Bible and it states the tq figures in in-libs and it states to use different torque figures on the center bolts than on the outers.....
There is a majour mistake there on Richard Nedball's book. And I was right about it, its waaaay too much torque!!! I see some people will strip their threads following the suggestions on that book.
Also, it states someplace else to torque the valley head bolts to the same torque as the rest of the head bolts....which will probably cause the intake valve seats to distort and not seal right....
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420299
04/15/13 06:03 PM
04/15/13 06:03 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I love Rich and his book is the best but it is wrong on this. Use the torque values and sequence in the Mopar Hemi engine book. That is the only way to do it right. The bolts will loosen up after you run it several times. Retorque every month until it settles in. If possible I prefer to use studs on aluminum heads. I get mine from ARP.
Re: HEMI: Intake to Heads Oil Leak [Re: rickseeman] #1420300
04/15/13 07:05 PM
04/15/13 07:05 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I read somewhere that because the bolts are verticle, if you over-tork the intake bolts, it can wedge the heads apart and crack the block!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420301
04/15/13 07:46 PM
04/15/13 07:46 PM
wappinger falls new york
Jimi_Vignogna Offline
domingo make sure it is not the cylinder head studs in the intake ports sucking oil up and through, also if the heads are ported do they have brass tubes for the push rod holes?sometimes those leak.
if those two parts are ok i would only use mr gasket intake gaskets, glue them to the cylinder heads and let the glue "set up", silicone the face of the gasket and the bottom of the intake ports, the silicone will allow the intake to slide down on the gasket as you tighten it down with out pulling the gasket with it.
is this a mp cross ram? or single 4 bbl? if it is a cross ram use lots of silicone down the bolt holes to keep them sealed as well.
Re: HEMI: Intake to Heads Oil Leak [Re: Jimi_Vignogna] #1420302
04/15/13 08:17 PM
04/15/13 08:17 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Its a stage V dual carb intake. Known as the RAT BUSTER.
I redid this once more. I put silicone both sides.
I torqued it down per the Mopar HEMI BIBLE and we'll see if this time around it seals.
The oil is seeping through from the intake to head joint. When I take out the carbs this intake is big enough to let me see that there is oil right at the seam between the intake and heads. every time is the same. Its the first time im using silicone on both sides of the gasket....lets see how it holds up this time....
I also put some goo on the outside bottom of the intake port so it seals up with the intake when torqued down, I hope it helps sealing...
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420303
04/15/13 10:11 PM
04/15/13 10:11 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i had this same problem on my motor. stage v heads and mopar performance x-ram(has very bad port alignment on bottom of runners) I glued the gaskets to the heads with 3m weatherstrip adhesive and ran a thin bead of silicone around each port. 6 years and no leaks. I have seen over tightening of the intake cause the heads to leak water out of the corners, retorqued and it was fine
Re: HEMI: Intake to Heads Oil Leak [Re: prochargedhemi] #1420304
04/15/13 10:54 PM
04/15/13 10:54 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Sorry guys. Definitely a typo there. I have been seeing a lot more of this problem lately. On the last few engine I did these steps:
* I glued the Mr. G 303G gaskets to the heads using Gasgacince.
* Bolted on the manifold for an hour to press the gasket to the head.
* Removed the manifold and trimmed the gasket to the port using an Exacto.
* On the manifold side I used "The Right Stuff" around each port, spread very thin with my finger.
* Bolted on the manifold using the torque sequence.
* Went over all the bolts several times until there was no more movement.
Not a leak since...
Re: HEMI: Intake to Heads Oil Leak [Re: Mopar_Rich] #1420305
04/15/13 11:41 PM
04/15/13 11:41 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Another thing to check is intake fit. Let's say the block was decked alot. Now the holes in the intake don't line up with the threads in the heads. The intake bolts end up hitting the sides of the intake. You can be tightening the intake and it feels snug but you are really just jamming the bolts. To check this, put intake manifold studs in the heads, (best without the intake gaskets on), and see if the intake manifold will slide all the way down to the head. If not you will have to get a rat tail file and elongate the holes in the intake manifold until it will slide down to the head without wedgeing into the studs.
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420306
04/16/13 12:04 AM
04/16/13 12:04 AM
Cab_Burge Online work
Cab_Burge  Online Work
Be very careful on which type silicone you use on intake gaskets, I like and use "adhesive" silicone only on any gasket that is exposed to oil Make sure the label says Adhesive silicone, not gasket maker or any other label Let it dry 24 hrs or more
Re: HEMI: Intake to Heads Oil Leak [Re: Cab_Burge] #1420307
04/16/13 12:25 AM
04/16/13 12:25 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I have pretty good luck with the Permatex gray..
I didn't read any comments for checking gasket thickness. If you have too thin a gasket, it could appear to be clamping down enough but isn't.
Re: HEMI: Intake to Heads Oil Leak [Re: 52savoy] #1420308
04/16/13 12:35 AM
04/16/13 12:35 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Had my intake off last week.Used the Mr G 303G and "The Right Stuff to glue everything back together
Thanks again Rich
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: HEMI: Intake to Heads Oil Leak [Re: rickseeman] #1420309
04/16/13 11:31 AM
04/16/13 11:31 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I caught this the first time around and elongated the manifold holes....still after doing this im still sucking oil into the intake ports.....
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420310
04/16/13 11:36 AM
04/16/13 11:36 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I glued it back on with grey silicone on both sides. Torqued the 4 center bolts more than the 4 outers....
we will see if the problem is solved this time around....
I used a set of MR Gasket 0,060 gaskets....even though they are thicker than what Id like to use for better port alignment(0,030 would be better) I am gonna try this time with the thicker ones to see if they seal better.
Port aignment is not exactly on center, its like the intake would like a thinner gasket to go down a bit more so the intake ports are more on center with the head ports....
although the intake is sitting a bit high and the ports are not perfectly concentric, I am still not seeing a "step" whhen looking down from the carb opening into the intake ports. The top oprtion of the intake runner is perfectly flush with the port roof on the heads, and the lower portion of the intake runner sits about 1/8" higher than the intake port...(the stage V intake ports are smaller than the head ports...the heads are CNCd and gasket matched,k the stage V intake is untouched, hence the smaller runner openings).
Re: HEMI: Intake to Heads Oil Leak [Re: hemi-itis] #1420311
04/16/13 11:54 AM
04/16/13 11:54 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If leaking at the bottom persist carefully check the following areas:
Head to manifold alignment(top to bottom)
Head to manifold angle and gasket thickness that's required.
Manifold to block rail spacing(make sure nothing is holding the manifold up)
Head intake surface flat and not cut at an incorrect angle front to back,Check same for the intake surface.
Make sure there is no warped surfaces.
The angle and straightness can be checked buy using four block(steel) guages at all four corners then check all the areas at each port for discrepencies and if the four corners don't set tight on the corner guages then you know something is out of square.
We usually use 2"X 1"X .060 thick block steel guages at all four corners and check for the manifold setting flush on the guages and then pass a aluminium welding rod flattened to just a hair under .060 through the port area to see if it's loose or tight in any one spot.
We never use any torque values when tightening the intakes but use a sequence of side to side and repeat till there is no more bolt rotation with a 1/4 drive then we repeat it after the engine has heat cycled a few times.We also recheck them every few seasons if the engine sets for long period of time.
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420312
04/16/13 12:01 PM
04/16/13 12:01 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Dom
what are you using to seal the ends of the intake to the block? Are you just using silicone or are you using the gasket that is supplied with the intake gaskets for the end rail. I had a problem with those gaskets holding the intake up too high and the intake gaskets would not seal properly. I left out those end gaskets on each end and just used silicone on the ends and then the intake gaskets sealed up on the ports with no leaks.
Just a thought
Old Geezer Racing
Re: HEMI: Intake to Heads Oil Leak [Re: SCATPACK 1] #1420313
04/16/13 01:10 PM
04/16/13 01:10 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yep guys, I checked all of that and it all seems to be OK.
So Ill run it one more time after all the MEGA SILICONE APPLY and see if it seals up good.
If not, its tear down time again...Ill recheck everything and use a different brand gasket and a different brand gasket adhesive.....
Thanks for all the suggestions!
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420314
04/17/13 08:29 AM
04/17/13 08:29 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Dom: cometic makes a thinner gasket, .045 I think, and that's what I ended up using. The only thing I did different was I glued the gasket to the intake so if I had to change it again I would not be scraping in to the lifter valley. That is for a newer mp cross ram on a street car. Dave
Page 1 of 3 1 2 3
