Disc brake conversion??? #1420048
04/14/13 08:46 PM
04/14/13 08:46 PM
abc440 Offline OP
abc440  Offline OP
I put front brake conversion kit mannual( new rotors, calibers, hoses,MC, spindle, pads) about 3 weeks ago. Had heating up rotors problem and front wheels being real tight to spin when getting back from 3 mile trips. Changed out MC (mannual), no heating up problems or tight wheels, but still a hard pedal and not much braking. Bled lines with hand vaccum pump 2 times, and once with helper pumping up pedal 3 or 4 pumps and holding, me releasing bleed screw with just a dribble fluid coming out of each screw,(just a couple a drops). What is wrong?And also do I need a power brake booster/MC? This is a 71 B-body with a mannual drum brakes oringally. How much trouble to put power on and where to buy booster.MC? Thanks
Re: Disc brake conversion??? [Re: abc440] #1420049
04/14/13 08:54 PM
04/14/13 08:54 PM
Andrewh Offline
Andrewh  Offline
so others better at this will respond, but basically it sounds like your first master cylinder still had the residual valve in it.
keeps 10 psi on the lines for drum brakes.
you replaced it with one that did not have the residual valve, but the diameter of the piston changed. so your braking effort changed.
There are specific recommendations for manual disc brakes and the master cylinder you should use.
it will be more pedal travel but easier braking.
I think they will need to know what calipers you are using to give you that recommendation.
Re: Disc brake conversion??? [Re: Andrewh] #1420050
04/14/13 09:44 PM
04/14/13 09:44 PM
abc440 Offline OP
abc440  Offline OP
Thanks, the only thing I know is they came with kit from Right Stuff, and replacement parts are for a 73 A body from parts house. How about the dribble drops when bleeding brakes with a helper pumping up brakes and holding, I was especting pressure on fluid.
Re: Disc brake conversion??? [Re: abc440] #1420051
04/14/13 10:34 PM
04/14/13 10:34 PM
Marion, Ohio USA
kab69440 Offline
kab69440  Offline
Marion, Ohio USA
Sounds like your hoses have collapsed. Are they new or recycled from another project?
Just because you're paranoid, it doesn't mean they are not out to get you. WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
Re: Disc brake conversion??? [Re: abc440] #1420052
04/14/13 10:35 PM
04/14/13 10:35 PM
blockage somewhere upstream. Undo the lines at the MC & see if there's good volume & work your way rearward checking at each connection
Re: Disc brake conversion??? [Re: RapidRobert] #1420053
04/14/13 11:15 PM
04/14/13 11:15 PM
abc440 Offline OP
abc440  Offline OP
They are new hoses. I will check for blockages tommorrow. Any ideas on power brake booster and MC and how hard to add since it is a mannual car?
Re: Disc brake conversion??? [Re: abc440] #1420054
04/14/13 11:25 PM
04/14/13 11:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Not sure on B-body but in a "C" you need to change the pedal assembly.
I have mechanical Aptitude.
I can screw up anything.
Re: Disc brake conversion??? [Re: abc440] #1420055
04/14/13 11:48 PM
04/14/13 11:48 PM
After you find/fix the blockage you might be Ok with the manual brakes
Re: Disc brake conversion??? [Re: abc440] #1420056
04/15/13 02:20 AM
04/15/13 02:20 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Not hard to change. You need a different firewall support plate, it has a round hole instead of a squashed square. You also need a pivot linkage that bolts to the pedal, the brake pedal assembly, and the power booster rod.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Disc brake conversion??? [Re: RapidRobert] #1420057
04/15/13 08:12 AM
04/15/13 08:12 AM
abc440 Offline OP
abc440  Offline OP
Could my distribution block under MC be bad since I am not getting much fluid to all 4 bleeder screws?
Re: Disc brake conversion??? [Re: RapidRobert] #1420058
04/15/13 07:53 PM
04/15/13 07:53 PM
abc440 Offline OP
abc440  Offline OP
Hey Robert, I unhooked brake lines from MC ports and had helper pump pedal, good stream from both ports. I took loose rear line from my new proportion valve and good fluid form pumping. Took bleed screw out each front wheel and pumped fluid. Buttoned everything up and bled again with hand pump with a cup full out each wheel (plastic cup that comes with pump kit). Drove and pedal feels a little better, not as hard pedal as before. Guess i will keep bleeding. Thanks dave
Re: Disc brake conversion??? [Re: abc440] #1420059
04/15/13 08:46 PM
04/15/13 08:46 PM
Progress I wonder what the blockage was. The symptoms sure didnt sound like air but sometimes they are tricky.
