Radiator core support paint scheme #1419793
04/14/13 12:31 PM
04/14/13 12:31 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
I know it's been covered before; however, I can't seem to find it in the search. What is the correct method and finish used for the radiator core support so the light body colors do not show through the grill? Thank you!
Re: Radiator core support paint scheme [Re: Airgrabber] #1419794
04/14/13 12:36 PM
04/14/13 12:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Lower yoke, latch support bracket, & both side panels get a semi-gloss black; also the inner areas of the fenders. On the line, they were sprayed from underneath, apparently at about a 45-degree angle upwards. Upper yokes weren't painted but I've seen overspray on some. It was done quickly and not masked off in a manner that would leave "hard-lines". If you do a search here, lots of guys have posted pics.
Re: Radiator core support paint scheme [Re: topside] #1419795
04/14/13 12:40 PM
04/14/13 12:40 PM
Pewaukee, WI
Pewaukee, WI
Thanks for your help! I still have not been able to find any pictures in the search category.
Re: Radiator core support paint scheme [Re: Airgrabber] #1419796
04/14/13 01:11 PM
04/14/13 01:11 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
what search did you use ?
I typed core support blackout in the little google search at the top of the page and it cam back with a bunch of threads with photos ...
Re: Radiator core support paint scheme [Re: JohnRR] #1419797
04/14/13 01:22 PM
04/14/13 01:22 PM
Pewaukee, WI
Pewaukee, WI
Ok. I'm bad. I went to the forum search page. Thanks.
