thrust button removal? #141978
10/26/08 08:21 PM
10/26/08 08:21 PM
Rochester, NY
dusterdood Offline OP
Rochester, NY
I've got a narrowed 8 3/4 and the center section is a '489 that has the thrust button, so my passenger side axle shaft doesn't go in all the way. Is there a link to a good page/thread where this has already been answered? Do all center sections have thrust buttons?
I might be able to grab one from my brother and get rolling while I sort this out.
Thanks guys!
Re: thrust button removal? [Re: dusterdood] #141979
10/26/08 08:39 PM
10/26/08 08:39 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
They are not hard to remove. They have a roll pin
that holds both halves together. They adjust the
bearing preload for tapered bearings.
Re: thrust button removal? [Re: Dart 340] #141980
10/26/08 08:46 PM
10/26/08 08:46 PM
Rochester, NY
Rochester, NY
From what I understand it could have the two 'buttons' or a thrust 'block'. The buttons have a roll pin you can see when looking at it through the side where the axle slides in? I can see it, but it won't come out. I wacked it with a 13/16" socket on an extension, and a large hammer, but it didn't budge.
Re: thrust button removal? [Re: dusterdood] #141981
10/26/08 09:08 PM
10/26/08 09:08 PM
Rochester, NY
Rochester, NY
I've looked it up, and I have the cone type sure grip. I read that it's hard to remove the thrust block from these. I guess you have to tear it all apart. Does anyone have a picture of the difference between the button/block so I know if I have to tear it apart?
mike
Re: thrust button removal? [Re: dusterdood] #141982
10/26/08 09:39 PM
10/26/08 09:39 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: thrust button removal? [Re: dusterdood] #141983
10/27/08 06:29 AM
10/27/08 06:29 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
It won't budge driving it. It does not drive through. The hole it is in is smaller than the button head. They have to be pulled out. The roll pin holding the 2 halves together will 99% of the time be broken anyway so that is of little consequences. For this reason I never use one. It is just to hold the 2 halves together for assembly purposes anyway.
