Threaded valve guides? #1419509
04/14/13 04:14 AM
04/14/13 04:14 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Have anyone an explanation? I took off a pair of old 906 heads from a running 383 and found this. Looks almost like someone has made threads in the valve guides, in all the exhaust, not intake...
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Threaded valve guides? [Re: HP2] #1419510
04/14/13 04:38 AM
04/14/13 04:38 AM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
Looks like they may have been knurled. Sometimes machine shops will run a knurling tool down the inside of the guide. The tool cuts into the metal leaving raised edges, which are then reamed. The idea is to make the insides of the guides a bit smaller, trying to make less slop between the valve stem and the guide, thereby cutting down on the amount of oil that passes through. It has been my experience that it only prolongs the life of the guide and lessens oil consumption short term.
Re: Threaded valve guides? [Re: elmor] #1419511
04/14/13 09:00 AM
04/14/13 09:00 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That's a short term repair to get the valve stem to guide clearance within spec.
Re: Threaded valve guides? [Re: roadhazard] #1419512
04/14/13 01:43 PM
04/14/13 01:43 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Knurling is pretty standard practice for a non-performance valve-job.
Re: Threaded valve guides? [Re: StealthWedge67] #1419513
04/16/13 02:08 AM
04/16/13 02:08 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Thanks for the education!
71 Duster 340
