Hand porting 6.1 heads? #1419496
04/14/13 02:50 AM
04/14/13 02:50 AM
NE OHIO
SRT440DUSTER Offline OP
NE OHIO
Anyone had experience with cleaning up 6.1 hemi heads by hand? Thinking of cleaning mine up and port matching.
Re: Hand porting 6.1 heads? [Re: SRT440DUSTER] #1419497
04/14/13 09:21 AM
04/14/13 09:21 AM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
It has been a couple years now, but I started to play with one. Remeber working on the head bolt bulge. Didn't tale all of it out but quite a bit and worked at blending in what I had left. and both sides of the floor was radius and blended in better than stock. Hard to explain but if you look it is pretty easy to see what I am talking about. Took me about 15 minutes of work and flow went from 302 to 320. Thought wow 15 minutes and 18 cfm but never got back to them anymore. Sold them.
Re: Hand porting 6.1 heads? [Re: Cuda367] #1419498
04/14/13 10:11 AM
04/14/13 10:11 AM
NE OHIO
NE OHIO
Great info.. Thanks!
Re: Hand porting 6.1 heads? [Re: SRT440DUSTER] #1419499
04/14/13 01:11 PM
04/14/13 01:11 PM
NE OHIO
NE OHIO
Bump for more info!
Re: Hand porting 6.1 heads? [Re: SRT440DUSTER] #1419500
04/15/13 12:21 AM
04/15/13 12:21 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Don't touch the short turn, its one of the few things you need to know to not make them worse.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
