'84 W100 tail gate #1418973
04/12/13 10:13 PM
04/12/13 10:13 PM
Boswell, PA
67PLY Offline OP
67PLY  Offline OP
Boswell, PA
Need an good idea on how to fix tail gate pivot pin on my '84 W100. Right side broke from fatigue/rust issues. Thanks.
Re: '84 W100 tail gate [Re: 67PLY] #1418974
04/12/13 10:42 PM
04/12/13 10:42 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Cut one from another good box or fab one up with pipe and sheet metal. No other way really
Re: '84 W100 tail gate [Re: 76dodgeboy] #1418975
04/13/13 07:50 AM
04/13/13 07:50 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I used a chunk of primary tubing from an old set of headers and brazed it on the gate.
Re: '84 W100 tail gate [Re: redraptor] #1418976
04/13/13 08:49 PM
04/13/13 08:49 PM
Boswell, PA
67PLY Offline OP
67PLY  Offline OP
Boswell, PA
Thanks ......
Re: '84 W100 tail gate [Re: 67PLY] #1418977
04/14/13 10:35 PM
04/14/13 10:35 PM
Boswell, PA
67PLY Offline OP
67PLY  Offline OP
Boswell, PA
Found a FORD repair kit on Ebay that may work ,,,,,
Re: '84 W100 tail gate [Re: 67PLY] #1418978
04/14/13 10:59 PM
04/14/13 10:59 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Wonder if the diameter is close. If not just weld them up higher.
Re: '84 W100 tail gate [Re: 76dodgeboy] #1418979
04/15/13 06:51 PM
04/15/13 06:51 PM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
Never really knew this was a problem with these trucks till I got the 90' that I just bought. The exact same thing right side broken off and gone, and this truck has been used VERY little as a truck. Then when I went to the first junkyard to try to find the piece to cut out of another truck they had 5 trucks to choose from and every one of them were the same way. Next yard there was one that the piece was still there but it was coming loose only holding on by about 1/2 the weld. I got it and I'm going to fix the poor weld before install and have it put in the truck, but at that yard there were two others exactly the same broken off right side pivot. The Ford pieces you have pictured look interesting although the one for the right looks a little small but may just be the picture.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: '84 W100 tail gate [Re: adventurer] #1418980
04/16/13 12:36 AM
04/16/13 12:36 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Sometimes a little squirt of white grease or a little oil does wonders. The only truck I had a problem with the tailgate on was the one where I backed into something with the gate down.
I have fixed a lot of other peoples hinge pins before though. Gene
