Page 1 of 4 1 2 3 4
anyone here run a 4l80e? #1418588
04/12/13 01:45 AM
04/12/13 01:45 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
I'm considering stuffing my Cuda with a 4l80e and wondering if anyone else here has done it already
with a 2.94 first gear and a .74 6th gear, the possibilities seem endless on how well it can work
plus I can swap between a gen 3 hemi and my BB with a simple bell change if I wanted too
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418589
04/12/13 01:51 AM
04/12/13 01:51 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
It will require cutting the tunnel. I have a 4L60 , its tight but it does fit with no cutting. 3.05 first gear , I run it with a 3:55 Dana
Re: anyone here run a 4l80e? [Re: brads70] #1418590
04/12/13 01:54 AM
04/12/13 01:54 AM
Charleston
Charleston
that would be no big deal. my car is a piece of junk anyway. do you use the TCI/fast controller for yours?
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418591
04/12/13 02:00 AM
04/12/13 02:00 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
No I'm using simple shift.
http://www.powertraincontrolsolutions.com/product/SimpleShift/
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418592
04/12/13 09:19 AM
04/12/13 09:19 AM
an8sec70cuda Offline
6th gear? You mean 4th? Or is there some aftermarket version of this transmission that has more gears?
Only 4L80e I had was in my 2500HD truck...it was flawless for 150k miles.
I wouldn't use a 4L60e behind anything making decent power. I've blown up 4 of them behind some pretty mild GM LS motors.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: anyone here run a 4l80e? [Re: an8sec70cuda] #1418593
04/12/13 09:32 AM
04/12/13 09:32 AM
Charleston
Charleston
oh crap, I thought they were a 6 speed like this TCI
http://www.tciauto.com/tc/transmission-packages.html/?main=4
goes to show how smart I am
and the gear ratios I posted are wrong too, lol. I suck
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418594
04/12/13 09:38 AM
04/12/13 09:38 AM
The 4L80e is basically a big electronic 4 speed overdrive TH400. The 4L60e is comparable to the TH350.
The 4L80e is a good trans for what you want to do, it's just physically big.
CHIP
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418595
04/12/13 09:54 AM
04/12/13 09:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I went with the 518 trans.. basically its a 727 with
OD and lock up.. I eliminated the lock up so I could
run a high stall regular 727 conv... the 518 has
a .69 OD ratio.... and the good thing.. it bolts right
up to a small block... they are a heavy trans and its
longer than the 727 with the OD in the tail shaft..
if you get one of the earlier ones all you need is
a switch to turn on the OD or the lock up if you wanted
to keep that... the reason I dumped the lock up is
due to the conv.. you cant get a high stall that will
have lock up and live(lack of clutch area in the conv)
Re: anyone here run a 4l80e? [Re: MR_P_BODY] #1418596
04/12/13 10:10 AM
04/12/13 10:10 AM
Will a 727 converter work in the 518 trans? Wondering if I had a 518 w/ an UltraBell on it to fit behind my hemi, could I use my current converter in it?
What year 518s only need the switch to turn the OD on?
Stupid question...the 518 doesn't need a computer to run it?
Sorry for the hijack Ray.
CHIP
Re: anyone here run a 4l80e? [Re: an8sec70cuda] #1418597
04/12/13 10:20 AM
04/12/13 10:20 AM
Charleston
Charleston
no highjack, I would like to know also. looking for options. I would love to drive my Cuda more and would if it got better fuel milage
Re: anyone here run a 4l80e? [Re: an8sec70cuda] #1418598
04/12/13 10:39 AM
04/12/13 10:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No... the standard 727 and the 518 type pumps use
a different drive lug set up... if you change the
input shaft and the pump you can use the 727 conv
BUT you loose the lock up when doing this(the pump
and conv for a 518 have oil paths that turn on the
clutch in the conv to have lock up)... there are 2
versions of 518... the late 80s has a single wire plug
and the early 90s has a 3 wire plug to control the
OD and or lock up... the single wire is what you
really want because it was a OD ONLY(no lock up) and
the 3 wire has both the OD and lock up but if you want
a high stall you nee to change the pump... if you
find a 518 that has the 7 pin connector that HAS to
use a trans controller(computer controller)... the
1 pin and 3 pin versions are what they call the "H"
version.. thats a hyd operated set up.. the 7 pin
is called a "E" version(electronic controlled)
Re: anyone here run a 4l80e? [Re: MR_P_BODY] #1418599
04/12/13 11:03 AM
04/12/13 11:03 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Thats not entirely true - there is a 3 pin 518 that uses a 727 converter ( it's a non lockup version ) and I have it bolted up to an early hemi. I didnt want the lockup or the different converter and this was my best option.
They are hard to find, I forget the specifics , but i found one locally as a core.
Re: anyone here run a 4l80e? [Re: DJVCuda] #1418600
04/12/13 11:12 AM
04/12/13 11:12 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
http://www.hotrod.com/howto/43323_mopar_overdrive_transmission_swap/
in this article they use the 3 pin - non lockup setup as the 1 pin setup is used for reverse lights.
Re: anyone here run a 4l80e? [Re: DJVCuda] #1418601
04/12/13 11:18 AM
04/12/13 11:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Never seen a 3 wire non lock up... it would be
sorta strange to have a 3 wire connector to work
just 1 thing in the trans... the single wire was all
I seen as just the OD version.... but I guess you
never know when it comes to Mopar
Re: anyone here run a 4l80e? [Re: MR_P_BODY] #1418602
04/12/13 11:51 AM
04/12/13 11:51 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I'm such a retard!!!
It's a 2 pin.... there are 2 pin and 3 pins - the 3 pin ones have lockup.
My apologies.
I have a 2 PIN - NOT 3 pin - these use the 727 converters and do not have lockup.
Re: anyone here run a 4l80e? [Re: DJVCuda] #1418603
04/12/13 12:15 PM
04/12/13 12:15 PM
Charleston
Charleston
can you get a bell to do the 518 to a big block?
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418604
04/12/13 12:20 PM
04/12/13 12:20 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
yes you can cut the bell off and use another bell or use this :
http://www.transmissioncenter.net/plug_for_518_nlu.jpg
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418605
04/12/13 12:27 PM
04/12/13 12:27 PM
Yep, there's an Ultrabell for this.
CHIP
Re: anyone here run a 4l80e? [Re: an8sec70cuda] #1418606
04/12/13 01:35 PM
04/12/13 01:35 PM
dogdays Offline
dogdays  Offline
JVX still in business?
R.
PS: The 4L80E in my 3/4 ton Suburban has 253,000 miles without an overhaul. It did lose a speed sensor at around 160,000 miles but it is replaced from the outside of the transmission and costs like $30. I need to replace the front seal, but after a quarter million miles I guess that's OK.
But it's big and weighs something like 187 lb without converter.
R.
Re: anyone here run a 4l80e? [Re: an8sec70cuda] #1418607
04/12/13 01:45 PM
04/12/13 01:45 PM
Missouri
galen Offline
galen  Offline
Missouri
I run a 4l80 in the belvedere, 3800 stall with lockup and trans brake.. Controlled by compushift adjustable controller on the dash. I had to modify the right header collector and the tunnel. I love it. 4.30 gears and 75mph cruise at under 3000rpm. With the compushift I can set pressure, shift speed, overdrive in and out all on the dash. It uses a TPS run off my dominator carb with a linkage. Shifts like a normal trans in drive. At 90% throttle or above it goes into race mode and up shifts at what rpm you program into it. It is on stout trans. I drive with hand controls so I needed a trans that once I put it in gear is hands off, thats why I opted for the compushift controller. I am using a Wilcap adapter and ATI 130 tooth flywheel. Downside is weight and size.
Page 1 of 4 1 2 3 4
