Hey guys!
I'm looking to put a fan shroud on the 22" aluminum radiator in my '69 Super Bee. The aluminum radiator that I have has the radiator hoses located in the same location as the factory rad.
The car is far from a correct restoration, so I'm not concerned with correct part numbers. I do see that these shrouds are now reproduced, but they seem to be quite expensive.
I will be making the mounting brackets myself.
Will any year A,B,C or E body 22" shroud physically fit and function in my '69 B-Body? My concern is that perhaps the radiator hoses, or the actual fan location is slightly different between years and body types.
Thanks for any help!
