22" radiator shroud #1418417
04/11/13 06:39 PM
04/11/13 06:39 PM
BC, Canada
Black_Bee Offline OP
BC, Canada
Hey guys!
I'm looking to put a fan shroud on the 22" aluminum radiator in my '69 Super Bee. The aluminum radiator that I have has the radiator hoses located in the same location as the factory rad.
The car is far from a correct restoration, so I'm not concerned with correct part numbers. I do see that these shrouds are now reproduced, but they seem to be quite expensive.
I will be making the mounting brackets myself.
Will any year A,B,C or E body 22" shroud physically fit and function in my '69 B-Body? My concern is that perhaps the radiator hoses, or the actual fan location is slightly different between years and body types.
Thanks for any help!
Paul
'69 Super Bee 383 EFI Turbo
Re: 22" radiator shroud [Re: Black_Bee] #1418418
04/12/13 06:27 AM
04/12/13 06:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65 B body I run a 65 C body metal shroud.From what I hear the OEs are hard to find and pricey.The C body fits perfect in my B body.Rocky
Chrysler Firepower
Re: 22" radiator shroud [Re: Black_Bee] #1418419
04/12/13 09:43 AM
04/12/13 09:43 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
See the last few posts on this re: aluminum radiator shroud.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=7651096
Re: 22" radiator shroud [Re: Exit1965] #1418420
04/12/13 02:53 PM
04/12/13 02:53 PM
BC, Canada
BC, Canada
thanks for the help guys!
Any more advice out there?
Think I might just have to cough up the $$$ for a reproduction shroud since every Mopar 22" shroud seems to be worth a fortune.
Thanks!
Paul
Re: 22" radiator shroud [Re: Black_Bee] #1418421
04/12/13 07:04 PM
04/12/13 07:04 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Thanks!
There is a repo 69 type shroud that is not as costly as the two piece metal 68 back shrouds that could probably be made to work. Mancini I think has them,i'm sure there are others I bought one a few years back at the nats in the swap meet area for a 22" rad for a 69 RR. Check around with other vendors.
Do a google search for mopar 22" rad fan shrouds,it lists several. Speedway Motors has one for not much money that you might make work with your alum rad.
Re: 22" radiator shroud [Re: Black_Bee] #1418422
04/12/13 10:54 PM
04/12/13 10:54 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I went cheap on my beater 360 '68 B'cuda. I have the 22" stock 68 radiator in the b'cuda, it came from the factory with no shroud. I found a 22" shroud from a mid-70's /6 Valiant in the boneyard. When turned upside down, the /6 shroud fits amazingly well on the V8 radiator with minor modifications (filing and drilling). Looks more or less stock at a quick glance (unless you look underneath where you see the "CAUTION FAN" warning upside down!).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 22" radiator shroud [Re: Black_Bee] #1418423
04/14/13 03:06 PM
04/14/13 03:06 PM
BC, Canada
BC, Canada
Thanks for the help guys!
Paul
