Axle housing studs versus B/RB exhaust studs #141827
10/26/08 07:22 PM
10/26/08 07:22 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Curious, are the double ended studs on the big block cylinder head to exhaust manifold the same as the center section mounting on an 8-3/4"
I had someone ask today, and I honestly don't know. I've never had one out of the rear diff.
Re: Axle housing studs versus B/RB exhaust studs [Re: gtx6970] #141828
10/26/08 07:38 PM
10/26/08 07:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
IIRC, the mounting bolts on the 8-3/4" are a flanged head bolt, not a screw-in stud. I got some from a ford dealer. They were the same as the brake mounting bolts on a 8.8" rear.
Re: Axle housing studs versus B/RB exhaust studs [Re: gtx6970] #141829
10/26/08 09:25 PM
10/26/08 09:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think I seen them for a 9" in the Jegs website.
Gus
64 Plymouth Savoy
Dana 60
Re: Axle housing studs versus B/RB exhaust studs [Re: fourgearsavoy] #141830
10/26/08 09:29 PM
10/26/08 09:29 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
8 3/4 housings have a knurled stud with a head on them. You can put the nut on them and pound them out. Think of a wheel lug stud. The trick I am waiting to hear is how to reinstall them. Pulling them in with the nuts does not work to well......
Re: Axle housing studs versus B/RB exhaust studs [Re: gtx6970] #141831
10/26/08 09:42 PM
10/26/08 09:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the stud in the housing for the center I am pretty sure is the same as the studs on the end axle tubes .
Re: Axle housing studs versus B/RB exhaust studs [Re: belv2vert66] #141832
10/26/08 09:47 PM
10/26/08 09:47 PM
Kirkland, Washington
Pacnorthcuda Offline
C-Clamp and a socket over the stud portion
Re: Axle housing studs versus B/RB exhaust studs [Re: belv2vert66] #141833
10/27/08 12:22 AM
10/27/08 12:22 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Hmm, that worked fine for me 2 weeks ago, just make sure you have a clean thread and the proper tall nut.
Re: Axle housing studs versus B/RB exhaust studs [Re: JohnRR] #141834
10/27/08 04:45 PM
10/27/08 04:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The center section studs are about 1/4" longer than the backing plate studs.
Mancini has a bubble packed hardware kit with all of the studs/nuts.
