Victor Max Wedge - T&D vs Harland Sharp Rocker Arms #1418201
04/11/13 11:47 AM
04/11/13 11:47 AM
Central California
MoParFish Offline OP
Central California
OK, I'm sure this has been covered before but, just throwin it out there before I pony up for new rockers... Being that Harland Sharps and T&Ds are both just over a grand for the Victors, is there any reason NOT to go with T&Ds ??
(512 Victor MW solid roller .674 lift with 1.6s Pac springs 240seat 625open .200 offset lifters). Haven't completely ruled out Hughes either but T&D offers a .725 intake offset vs Hughes .600... Thanks...
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: MoParFish] #1418202
04/11/13 11:54 AM
04/11/13 11:54 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I only needed the intake rockers having used HS allready on iron heads and that saved me some $$.
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: Clanton] #1418203
04/11/13 12:05 PM
04/11/13 12:05 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Go with T&D and don't look back. They are as nice as they get when it comes to quality. They also have the best adjuster around, ball-ball pushrod and it oil the pushrod directly at the tip through the adjuster.
Good Luck and keep us posted on what you do.
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: MoParFish] #1418204
04/11/13 12:22 PM
04/11/13 12:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you looking at the single shaft(conventional mopar)
or the multi shaft... its hard to beat T&D rockers...
I dont know what offset you need to fit your heads...
but all I run now days is T&D rockers
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: MR_P_BODY] #1418205
04/11/13 01:12 PM
04/11/13 01:12 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have used both and both are quality pieces.
But T&D are definitely a cut above in my opinion.
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: MoParFish] #1418206
04/11/13 01:52 PM
04/11/13 01:52 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Was looking at the Hughes myself as I've got some standard port Victors in the closet. Don't really recall hearing anyone breaking Hughes rockers.
Anyone had bad experiences with Hughes rockers?
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: 80fbody] #1418207
04/11/13 05:46 PM
04/11/13 05:46 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
I had lots of problems with Hughes on victors was running 275 seat and 625 open pressure. Ended up getting them bushed and still having failrues. Went to Harland Sharps and never looked back. This is a turbo application so its a bit harder on rockers. Made 1500RWHP on victors so far, but they are pretty much at their limit.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: Efidart] #1418208
04/11/13 08:21 PM
04/11/13 08:21 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had these Hughes rockers on my EZ heads sinve 2011 with good results. But these are not the offset rockers. My brother has run Hughes for years also with no trouble but his also are not the offset ones.
Just curious what the offset Harland Sharp and T & D's go for as compared to Hughes ? But you have to use what works for you. Ron
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: MR_P_BODY] #1418209
04/12/13 10:06 AM
04/12/13 10:06 AM
Central California
Central California
Single shaft. Thanks everyone for the replies...
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: Efidart] #1418210
04/12/13 10:26 AM
04/12/13 10:26 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have run Hughes' standard-offset rocker successfully and have their offset ones to use w/ my new Victor heads. Please define "lots of problems", as that's too general a statement to help identify possible source(s) of the issues you've experienced.
If the Hughes setup doesn't cut it for me, I'll go T&D since I'm not a big fan of Harland Sharp.
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: BradH] #1418211
04/12/13 12:29 PM
04/12/13 12:29 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Bad galling on the shaft, the rockers would loosen up between lashes constantly. So after speaking to hughes they referred me to a place that would bush my rocker arms which should have cured the problem but only was a bandaid fix that lasted a short period. The money I spent on the Hughes I should have got off my wallet and bought the Harland sharps right off as they have been trouble free since I put them on.
If your running any hyd or a small solid cam i'm sure you wouldn't run into the problems. Being boosted and probably making the most power on a set of victor heads in the world (good bet?) the rockers get taxed pretty hard. Tho predator heads are my next purchase.
I have a nice used set of Hughes rockers for cheap if you'd like..
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: Efidart] #1418212
04/12/13 02:18 PM
04/12/13 02:18 PM
BradH Offline
BradH  Offline
I only ran mine with 180# closed & 400#s open before, but I also run thicker rocker shafts than what Hughes supplies (RAS pieces), Smith Bros. adjuster screws (which IMO are better than the adjusters that Hughes used to supply w/ their rockers) and have my #4 cam journal grooved for full-time oiling to the rocker shaft.
The Victors will be set up w/ the same shafts, adjuster screws and full-time oiling, but will subjected to 240# closed and close to 600# open, so I'll be checking the valve train pretty closely when it comes back to life. Time will tell...
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: Efidart] #1418213
04/13/13 01:25 PM
04/13/13 01:25 PM
Central California
Central California
Do you recall how the scrub distance/pattern looked with the Harland Sharps? Lash caps? Also caught your license passes on Youtube. You're puttin the power down
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: MoParFish] #1418214
04/14/13 07:51 AM
04/14/13 07:51 AM
tboomer Online work
tboomer  Online Work
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: MoParFish] #1418215
04/14/13 10:48 AM
04/14/13 10:48 AM
BradH Offline
BradH  Offline
I'd like to know, too. However, what seems typical of HS rockers on Edelbrock big-block heads is that their scrub pattern is heavily biased to the exhaust side of the valve tip. Even the Hughes stuff that has a shorter fulcrum-to-roller c/l distance than the HS still has a bit of an exhaust-side bias, but no where near as extreme.
I don't think that T&D had got it "nuts on", either, since their fulcrum-to-roller c/l spec for rockers used on Victor heads is 1.52, which is pretty close to what the Hughes are.
The rockers which IIRC actually showed the best scrub pattern on Edelbrock big-block heads were the Crane golds, which (I'd have to check my notes... somewhere) are about 1.48, but Crane never produced anything w/ the correct intake pushrod offset for the Victors. Also, Crane's have other issues IMO that make them less than ideal for this type of application. But perhaps that's just me...
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: BradH] #1418216
04/14/13 10:57 AM
04/14/13 10:57 AM
tboomer Online work
tboomer  Online Work
Brad...Why don't you like the H.S.rockers? And put that damn thing together!!
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: tboomer] #1418217
04/14/13 11:03 AM
04/14/13 11:03 AM
BradH Offline
BradH  Offline
I've posted my issues w/ them in the past and all that did was bring out the HS-lovers to bash me for not liking them. No point in going through that all over again. You'll just have to respect that I have an opinion that is shared by some others via PMs who also choose not to get involved in a over the subject.
I'm trying... but all the progress I made in the fall came to a grinding halt around the Holidays and I've been unable to get back into thing seriously since then.
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: BradH] #1418218
04/14/13 11:07 AM
04/14/13 11:07 AM
tboomer Online work
tboomer  Online Work
OK..Fair enough! I know a guy that has 8 T&D exhaust rockers. But you still would need the the intakes and shafts. I think the intake rockers are 76.00 ea!!
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: tboomer] #1418219
04/14/13 05:14 PM
04/14/13 05:14 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Brad I did also have problems with the hughes adjusters and went to the smith adjuster screws which seem to be a lot higher quality metal.
The scrub pattern on the HS rockers did sweep towards the exhaust side, I ran lash caps with both sets of rockers.
Maybe the newer Hughes rockers are better but I do think a big solid roller is a bit taxing for the hughes and to get something like a T&D or HS for the bigger spring pressures.
The only reason I bought HS rockers was from the recommendation of other victor head owners and seem to work very well. The T&D are a good rocker but haven't had the chance to try a set.
The last race of the year finally got it to hook out of the hole. Race weight is 3500~.
Pass w/HS rockers
Re: Victor Max Wedge - T&D vs Harland Sharp Rocker Arms [Re: Efidart] #1418220
04/15/13 09:46 PM
04/15/13 09:46 PM
Central California
Central California
Pass w/HS rockers
Now that is cool!!
