68 coronet ralley frame -1970 superbeedash frame #141805
10/26/08 06:16 PM
10/26/08 06:16 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Will a 70 dodge superbee ralley dash frame interchange with a 68 dodge coronet rally dash frame ?
Re: 68 coronet ralley frame -1970 superbeedash frame [Re: gtx69] #141806
10/26/08 07:27 PM
10/26/08 07:27 PM
I would have to run the supercessions to be sure, the part #'s in the book are different. The 70 book has options like A/C as well.
I would say though that if the 68 Coronet frame is from an R/T, Superbee or other car with the round rallye guage package, and the 70 is also (with no A/C) it is quite likely to work.
If you are trying to change from square gauge to round---no.
Re: 68 coronet ralley frame -1970 superbeedash frame [Re: gtx69] #141807
10/26/08 07:27 PM
10/26/08 07:27 PM
oregon
daytonakid Offline
daytonakid  Offline
oregon
The dash pads are different. 68 is pointed 70 is not. The mounting for the ignition lock is in dash on 68 but in column on 70. 68 radio is thumbwheel and 70 is knobs. And if they are ac they are different. But you might be able to make them work with some mods. Bill
