96 Dakota ball joints
#1417986
04/11/13 12:35 AM
04/11/13 12:35 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Preparing for the fight of changing the ball joints on my 96 . All ball joints are in the freezer this week.....going to rent the tool kit from Oreilly soon. Ive been oiling the crap out of everything in advance... So--these are press in type. Im looking for any tricks you might have to make the fight easier ![](/ubbthreads/images/graemlins/grin.gif) On the upper---can I change it without taking the upper A arm off the truck ?? The lower-- can it be done without removing the lower ca ? Ive got some 4 ft pipe ready for leverage...and a torch...
Re: 96 Dakota ball joints
[Re: 493_DART]
#1417987
04/11/13 06:58 AM
04/11/13 06:58 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
If they are like my 99 Durango they can be done without R&R ing the arms.I use a ball joint press and my good impact.I remove the knuckle to get more room.I know my lowers you have to check the snapring for clearance.I did all 4 at the shop in about 1/1/2 hours.Did the ones on my kids 83 Ram in the drive in about 2 hours. Rocky
Chrysler Firepower
[Re: 493_DART]
#1417989
04/11/13 05:31 PM
04/11/13 05:31 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Hopefully the pressing tool has all the right adapters and make sure they start straight. Also, you do know the uppers are screwed in--right? Make sure you get the socket for it, and be just as careful making sure they go in straight. I used a 1/2" breaker bar and a long pipe to get them unscrewed, switched to a ratchet when they broke loose.
BTW, a LITTLE heat will help, you just want enough to help break things free, but honestly, I never used heat on any B/joints I have done.
Outcast Dodge guy.
[Re: 493_DART]
#1417991
04/12/13 01:30 PM
04/12/13 01:30 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
are you sure the uppers are screwed in ??? everyone ive talked to said they press in.
the look like they have "ridges" not angled threads...
There not a true 'thread' say like a bolt but yes they are supposed to be threaded in until they bottom out. FWIW when I changed the uppers/lowers on my B-van I managed to unthread the uppers and after fighting with the replacements I said F-it and just pressed the new threaded ones into the arm and called it done. Right or wrong I dont know, havnt fallen out yet.
[Re: 493_DART]
#1417993
04/13/13 12:38 AM
04/13/13 12:38 AM
493_DART
Worst Weather USA
Rented the press tool kit. Cant even budge the 1st lower. 5' of pipe/breaker ...heated with torch...etc... Im throwing in the towel. F this. Im throwing on the new tie rods and calling it good. 96 Dakota ball joints for sale -- brand new ! ![](/ubbthreads/images/graemlins/grin.gif)
[Re: 493_DART]
#1417995
04/13/13 08:17 AM
04/13/13 08:17 AM
85_Ram_4speed
WOW, Thats it!? I hope the ball joints weren't real bad then. I have had to deal with a broken ball joint and trying to recover the vehicle to get it home. It sucked. Good luck though, I hope they never fail on you and hurt yourself or someone around you.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1417996
04/14/13 12:16 AM
04/14/13 12:16 AM
493_DART
Worst Weather USA
and what do you expect me to do?? break my breaker bar ? You are welcome to come over and try to break these loose !! ![](/ubbthreads/images/graemlins/grin.gif)
[Re: hp383]
#1417999
04/14/13 05:35 PM
04/14/13 05:35 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
