Re: Piston top thickness [Re: RapidRobert] #1417942
12/07/13 11:54 PM
12/07/13 11:54 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Hey I am a stickler for accuracy & I am wrong on occaision. I'll check that site out. EDIT I'm thinking (Area X Pi X radius squared) times .035" would be the addit'l volume removed then you'd convert from cubic inches to CC's then you'd add that number to the original valve relief CC amount. Sound good or bogus?
If the floor of the valve relief were parallel with the piston top, or if the existing relief is deep enough that it is a full diameter that would work but on a small block the valve reliefs are 18 degrees from being parallel and generally not deep enough to be a full diameter. Or just break out the burette and piece of Lexan if they are flat tops.
Re: Piston top thickness [Re: GTS340] #1417943
12/08/13 01:16 AM
12/08/13 01:16 AM
or if the existing relief is deep enough that it is a full diameter that would work.
Alright now I grasp the tilted cyl in the site
Re: Piston top thickness [Re: RapidRobert] #1417944
12/08/13 10:51 AM
12/08/13 10:51 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I would have pulled that engine and find out all about the internals before doing anything destructive...Something is wrong, and small corrections may not be enough. My
Re: Piston top thickness [Re: Oyvind Mopar] #1417945
12/08/13 04:16 PM
12/08/13 04:16 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
I might have first wondered why no reply 8 months ago before deciding to drag this one up from the dead .
But for the OP , I would have pulled a piston also , this sounds like a small block also ...
