Dana rear question #1417919
04/10/13 10:57 PM
04/10/13 10:57 PM
crisfield, maryland 21817
8
82ramIndy493 Offline OP
Are the u-bolts and plates that hold a Dana rear to the springs different than an 8 3/4? Am installing a built up Dana in my race truck to replace the 8 3/4. Truck is at a chassis shop getting done and I did't check to see if they were the same. Will need to find some if they are different.
Re: Dana rear question [Re: 82ramIndy493] #1417920
04/10/13 11:11 PM
04/10/13 11:11 PM
It depends on the axle housing diameter, if your Dana 60 is a original Mopar or a aftermarket with three inch diameter tubes your old parts will fit and work fine If it is a Truck or Van 3/4 ton cut down with 3 1/8 or 3 1/4 inch axle tubes they won't, measure yours to see
Re: Dana rear question [Re: Cab_Burge] #1417921
04/12/13 10:42 PM
04/12/13 10:42 PM
8
Thanks. I did find out mine was a 3 1/8 diameter. Have new u-bolts coming.
