1969 Road Runner steering Wheel #1417834
04/10/13 06:21 PM
04/10/13 06:21 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Are the 69 Road Runner and Coronet 3 spoke steering wheels the same?
Re: 1969 Road Runner steering Wheel [Re: 68GTS383] #1417835
04/10/13 11:07 PM
04/10/13 11:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I believe they are. Check on the Hamtramck Historical site in the trim & option guides as there may be a difference in which cars would get a full horn ring and which would get the 2/3 version. IIRC, RRs got 2/3 ring. '69 RR had its own center cap featuring the bird.
I've never seen an original base-interior RR with an upgraded steering wheel that I could confirm was correct, but the options/trim pages on the HH site & the car's line sheet ("broadcast sheet") will tell you what the car should have. Decor Group cars got the Satellite or upgraded woodgrain wheel, and to the best of my knowledge not the base (Belvedere) wheel.
Re: 1969 Road Runner steering Wheel [Re: 68GTS383] #1417836
04/11/13 10:14 AM
04/11/13 10:14 AM
The 3 spoke wheel that takes a horn ring is the same from 67-69 on all A and B bodies. Only difference is color of the wheel and what rings goes on it.
