Smokey exhaust, compression test - now what?
#1417674
04/10/13 10:15 AM
04/10/13 10:15 AM
Posts: 1,629 OH
Red383
OH
Last year at the end of the season my car started smoking real bad at idle, and I would notice the smoke between gears while driving the car. Didn’t notice any miss or strange noises. I changed out all the valve seals, thinking that was the problem (they all looked new, but I swapped them anyway). I parked it for the winter and now am getting back to it. It’s a 383 .030 over with KB hyper. Pistons, 906 heads, hydraulic cam, performer RPM intake, Edelbrock 750. 4-speed Trans. Has around 7000 miles on it since rebuild years ago (don’t drive it much). Smoke was a blue/white color.
I pulled all the plugs last night, all the plugs look the same, except for #8 which appeared to be wet. I unplugged the coil and propped the carb wide open. I did a compression test on each cylinder. #1 – 150 #2 – 150 #3 – 155 #4 – 150 #5 – 160 #6 – 155 #7 – 160 #8 – 95
So I put a couple squirts of oil in the #8 cyl and turned the engine over and then did the compression test again, and it showed maybe 10 on the gauge. So now what? I’m not much of an engine tuner, and I don’t know anything about carbs. What do these results tell me? What is the next step to take?
Thanks for the help.
Re: Smokey exhaust, compression test - now what?
[Re: Red383]
#1417675
04/10/13 10:16 AM
04/10/13 10:16 AM
Posts: 1,629 OH
Red383
OH
[Re: Red383]
#1417677
04/10/13 10:38 AM
04/10/13 10:38 AM
Posts: 12,093 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you can, take the guage off of the compression tester and replace it with a valve and air chuck. Then bring #8 up on compression stroke, hold the crankshaft in that position and put some air to that cylinder. It doesn't take a lot.
You can listen to the carb, exhaust, and breather to hear where the air is escaping the cylinder. Of course, hearing air from a valve cover breather means the biggest headache.
This is a simple and definitive test that will point you in the right direction.
Master, again and still
[Re: Red383]
#1417680
04/10/13 03:05 PM
04/10/13 03:05 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The valve has a bad spot on the sealing ring, like a notch or chip, that allows the combustion gases to escape. More typical on the exhaust due to the higher temps. Refering to a burnt valve is refering to the way the bad spot was created. As in a spot was burned in the edge of the valve.
But there are other things that can cause a valve not to seal properly and allow the loss of some or even all compression on that cylinder.
[Re: DaveRS23]
#1417681
04/10/13 03:10 PM
04/10/13 03:10 PM
dogdays
Head gasket. That plug is unnaturally clean. My R.
[Re: Red383]
#1417682
04/11/13 12:30 PM
04/11/13 12:30 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
White smoke is from water.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: DaveRS23]
#1417683
04/11/13 10:18 PM
04/11/13 10:18 PM
Posts: 1,629 OH
Red383
OH
I had a few minutes tonight and put the cylinder at tdc (I think), and put air pressure on it (can I apply too much pressure?) and held the crank. I can feel air coming out of the valve cover breather above the cylinder, and I can hear the air at the exhaust tips, but not feel air. Nothing at the carb.
I may try it again to verify I had it at tdc. Air at breather= rings? Air at exhaust = Burt valve?
The plugs in the engine a pretty new, less than 50 miles, and it really looks like that # 8 plug is new, maybe there is no spark in that cylinder? I'll have to check the wires for spark.
I will double check my findings, maybe after putting it back together and running it for a while.
[Re: Red383]
#1417684
04/12/13 11:02 AM
04/12/13 11:02 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Air test another cylinder or two so that you can get a comparison to judge by. Make sure that the exhaust valve is closed, there shouldn't be any air out the exhaust.
There is often some air past the rings, especially the more pressure you use. But not a lot, which is why I suggested to do another cylinder or two for comparison. Use about the same amount of air pressure.
If the air continues out the exhaust, loosen that rocker to be sure that is not an issue.
Air out of the breather indicates a cylinder sealing issue, not necessarily the rings. And the exhaust air points to the exhaust valve sealing, not necessarily a burnt valve.
A little more driving probably won't hurt anything, but it is looking like pulling that head is becoming more and more likely.
Keep us posted.
[Re: DaveRS23]
#1417685
04/12/13 11:13 AM
04/12/13 11:13 AM
Posts: 5,162 CT
GTX MATT
CT
Keep us posted.
I agree check another cylinder or two for comparison on whats leaking into your crankcase. Something is always going to leak past the rings. As noted there should be NO air escaping the valves.
[Re: dogdays]
#1417687
04/15/13 12:09 PM
04/15/13 12:09 PM
Posts: 1,629 OH
Red383
OH
I wasn't saying the plug was new, I mant that it looked new (really clean)
I put the plugs back in the engine, checked for spark on the plug wires (I had spark). I took the car for a little spin and it really is running good, but halfway through I noticed the smoke while sitting at a stop sign.
Came back to the shop, let it idle in the driveway and checked the temps of the header tubes at the head. #'s 3,5,4,6 where in the 400 degree range, #'s 1,2,7 where in the 300-325 range, and # 8 was around 150 degrees. (Not sure what this tells me, just thought I check it)
I pulled the plugs (#8 really clean and wet with oil) and did the compression test after it cooled a bit, and #8 was very low on the compression, around 30 PSI. It was also spitting oil when I was turning it over.
I am going to try the air in the cylinder to listen for leaks on a couple cylinders again, and then start pulling the head.
Re: Smokey exhaust, compression test - now what?*UPDATE*
[Re: Red383]
#1417689
02/14/14 01:47 PM
02/14/14 01:47 PM
Posts: 5,162 CT
GTX MATT
CT
Yeah sounds like you've got a cracked head, referring to your later posts from last April it makes sense. Car got hot and compression went lower as the crack expanded. As far as what to do, there are hidden expenses in switching to aluminum heads that people won't mention when they tell you that you're money ahead going aluminum. That said you'll gain some power, and if you've got the money and want more power then go for it.
[Re: GTX MATT]
#1417690
02/14/14 03:16 PM
02/14/14 03:16 PM
RapidRobert
might be head gasket/warped block/warped head. I'd have your machinist check the block deck for flatness, same with the head. I've never seen an unported 906 that was cracked but I have not worked with an abundance of em so you could very likely be an exception to my (limited) exp in that area. Wouldn't hurt to check long shots like thread depth while you are there. Holler how it goes.
[Re: Red383]
#1417691
02/14/14 03:46 PM
02/14/14 03:46 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
I know it's been a while, but I finally got around to pulling the engine. When I pulled the intake, I looked down the head on the #8 cylinder and could see coolant sitting on top of the valve. Dogdays was right. How does coolant get on top of the valve? Must be a crack? I pulled the head and found the exhaust valve on that cylinder is clean compared to all others, I assume this is from the coolant cleaning it.
So do I have the head checked for cracks? Is it worth putting any money into iron 906 heads for a street car?
Try to find a machine shop that can pressure check that head to find the crack, it might be fixable, maybe not. I would pull the #8 piston out and look real hard at it, especially the top and 2nd ringlands, look for corrosion, wear and damage to the piston including a collapsed skirt As far as replacing one 906 head versus buying new aluminum heads that is a decision you will have to make
