magnum 5.9 with a 904 flex plate
#141767
10/26/08 05:49 PM
10/26/08 05:49 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
Is anyone running an externally balanced Magnum 5.9 with a 904 transmission. if so what flex plate are you using? Are the weights on the flex plate or the tc? The only plate I have been able to find is for a 727 by B&M. Thanks
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
Re: magnum 5.9 with a 904 flex plate
[Re: goldmember]
#141770
10/26/08 06:31 PM
10/26/08 06:31 PM
blk00rt
Michigan Troll
thanks Ill talk with the dealer and see what they have.
[Re: blk00rt]
#141771
10/26/08 09:19 PM
10/26/08 09:19 PM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I am running the B&M with the cut out on it. If you need to, weight the converter.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
