Re: Will C body HP manifolds fit my 68 Charger?
[Re: Mr.Yuck]
#1417591
04/10/13 12:15 PM
04/10/13 12:15 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
What's everyones opinions got to do with the OP's question anyway? Ya, the C body exhaust manifols will work in your car. You will just have to bend the exhaust pipe the right way, to fit the flange, and around the steering column shaft.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Mr.Yuck]
#1417595
04/11/13 11:51 AM
04/11/13 11:51 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
I don't know how you are going to bend up a drivers side pipe that would clear the column with something like this.
That's why you do the job you do and don't work in a custom exhaust shop
I put that exact manifold in my dart on a 383 and it will work with a custom bent headpipe, maybe make it up from mandrel bends .
If the flange isn't pointing right at the steering column there is more romm in a 68 b body engine compartment than a 69 a body .
[Re: BigMoneyLewis]
#1417597
04/11/13 12:10 PM
04/11/13 12:10 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
You can find loose B body driver side HP manifolds at swap meets, ebay etc. for $ 100 or so if you look .
Greg
Bingo.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
