Best way to clean 69 RR dash Pads #1417525
04/09/13 08:27 PM
04/09/13 08:27 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
My lower pads are still soft but covered in grunge from being in storage
What is the best way to clean vinyl? Thanks!
Re: Best way to clean 69 RR dash Pads [Re: 68GTS383] #1417526
04/09/13 08:35 PM
04/09/13 08:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Kinda depends on the grunge: try some dish detergent, glass cleaner, Simple Green, or a product designed for cleaning vinyl, or grease & wax remover, as ascending levels of grime require. Grease & wax remover is fairly harsh for vinyl. A medium-stiff brush helps get junk out of the grain. Much easier to clean if not installed.
