Distributor Springs needed and some info #1417476
04/09/13 06:23 PM
04/09/13 06:23 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
Well for some reason i cant find a new Mopar performance Electronic Distributor on this earth I am going to redo my old unit.
!st where do I get the advance springs that were in the older units when they were new?
Also in my Smothers Brothers super tune video he says I need to put in a stiffer spring for a stable timing. Is there a spring kit out there for the older Dist's?? I know there is one for the newer units to recurve them.
Just to be clear on what I am doing I am going to attempt to weld my slot in my dist and play around with it to get my total timing in.
Also the springs I have in this thing now are so light it fully advances the timing at 500-600 RPMS.
I need the original springs as a starting base or a bit stiffer....
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417477
04/09/13 06:27 PM
04/09/13 06:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have an old points distributor kicking around , use the springs from it . None of the replacement spring kits I have ever seen have the stock springs. I save old distributors so I have parts when I need them.
Re: Distributor Springs needed and some info [Re: JohnRR] #1417478
04/09/13 06:31 PM
04/09/13 06:31 PM
Mansfield,Ohio
Mansfield,Ohio
BB not sure I do know there is a small block points dist out there somewhere, would they work?
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417479
04/09/13 07:54 PM
04/09/13 07:54 PM
If that's an online video would you post it. A old OE dist will work fine as bushing wear is negligible in a non points dist & only difficulty is having to go inside each time to adj the slots or springs but when you're done you're done. Grab a light spring from any parts dist you have & a mr gasket 925B or MP light spring kit & use one of em instead of the thick heavy spring with the long loop on one end. Then set initial with the vacuum gauge method then with that figure in hand set the total (slots) with vac adv disconnected/plugged. then work with springs then hookeup/adj vac adv. See if you can retrieve prior threads on this (I tried & no luck with the search function)
Re: Distributor Springs needed and some info [Re: RapidRobert] #1417480
04/09/13 08:19 PM
04/09/13 08:19 PM
Mansfield,Ohio
Mansfield,Ohio
The video is not online its their recent video (DVD) on super tuning. He said to use stiffer springs in the dizzy to keep the timimg from fluctuating between idle in park and putting it in gear.
The guy who messed with this before me and mucked it up took out the original springs and put in a set of MP light springs. They are both LIGHT. This thing seems to advance fully at idle.
I am starting over from the beginning and I need to get this timimg correct before I proceed.
Does any one know why you cant get a new MP Elec Dizzy with the adjustable advance.
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417481
04/09/13 08:22 PM
04/09/13 08:22 PM
Mansfield,Ohio
Mansfield,Ohio
And just for clarification, I have a old style MP Elec dizzy, I cannot use the springs from the recurve kit for the new style with the adjustable advance curve, correct?
Re: Distributor Springs needed and some info [Re: JohnRR] #1417482
04/09/13 08:24 PM
04/09/13 08:24 PM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
Not to hijack, but do you know what RPM the points springs come in at?
Re: Distributor Springs needed and some info [Re: Mapandjlp] #1417483
04/09/13 08:31 PM
04/09/13 08:31 PM
BDW Online content
BDW  Online Content
Check this out, I'm going this route eventually.
https://board.moparts.org/ubbthreads/show...rue#Post7545611
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417484
04/09/13 08:42 PM
04/09/13 08:42 PM
Using both MP light springs will let it start advancing at ~600 RPM, way too low in most apps. I would take both of em out & sub in both of the OE springs from one of your parts dists then set your initial with the "vacuum gauge method" then with that math figure in hand shorten the slots to get 35 total (SB) & 36 to 38 total (BB) with vac adv disconnected/plugged then adjust the springs then hookup/adjust the vac adv & the procedure for the springs and vac adv is too long to type out again when it's there in the search function somewhere I just dont have any luck with the search function. then tossing the heavy spring with the elongated loop on one end & subbing back in ONE of your MP light springs & keeping the OE light spring will be a good start. Not sure why there's no new MP dist available except that they might be on back order but imnho you dont need one, you're set with what you have.
Re: Distributor Springs needed and some info [Re: BDW] #1417485
04/09/13 08:49 PM
04/09/13 08:49 PM
Mansfield,Ohio
Mansfield,Ohio
That looks like it might be a good idea, only problem I see is it has only has 3 options to set the total.
Re: Distributor Springs needed and some info [Re: Mapandjlp] #1417486
04/09/13 08:53 PM
04/09/13 08:53 PM
Hijack away it's all for the greater good. Actually it's not dependant on if it's a point or electronic dist. A single OE light spring (out of any dist) will come in at ~850 & 2 OE light springs ~900 & /6's used a SLIGHTLY lighter spring than V8's did which'll lower the tip in RPM slightly. Always (in most cases) want to use at least (1) OE light spring plus one of the aftermarket springs & never use the OE heavy spring with the elongated loop on one end. EDIT that's why you cant go anywhere with the dist till you set your initial and your idle speed as you want it to start advancing several hundred RPM above your in gear idle speed that you'll see at the stoplight (or neutral if a non 904 guy). #1 #1 Get the weights tight with some heavy springs & set the initial timing with the VG method & even if you get one of the new MP dists you still can set your desired initial timing/idle RPM right now with the current dist
Re: Distributor Springs needed and some info [Re: RapidRobert] #1417487
04/09/13 09:03 PM
04/09/13 09:03 PM
Mansfield,Ohio
Mansfield,Ohio
RR quick question, its does not matter which slot you weld correct, and it needs to be the inside of "ONE" of the slots...correct?
Also how do I determine which spring goes where??
I have found a Old Dizzy and I have the Mr gasket springs on there way here now. need to get the welding done and I can start tuning!!
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417488
04/09/13 09:23 PM
04/09/13 09:23 PM
You sound pumped! Weld both slots on the outside & the dimention for how much slot length you need is in the archives but it ain't dead on accurate so go a bit shorter then elongate the slot(s) with a rattail file as you tune it to get it fine tuned (keep both sides equal). If you are using (1) spring it can go on either side & if (2) springs it does not matter which side which one goes on as the cam plate always advances in a linear fashion (the elongated loop spring that you toss is an exception). You'd want to weld the inside of the slots if you were using a non Mopar (longer) spring(s) otherwise the assy (with that) would flop till the weights moved out & the slack was taken up
Re: Distributor Springs needed and some info [Re: RapidRobert] #1417489
04/09/13 09:53 PM
04/09/13 09:53 PM
Mansfield,Ohio
Mansfield,Ohio
oh i am. i parked it last fall totally fed up and disgusted from all the bad advice and contradictory fixes. i read up on my holley and now understand that and have a firm grasp on this timing and ubderstanding that. i am ready to enjoy this car...finally!!!
THNX!!!
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417490
04/09/13 10:53 PM
04/09/13 10:53 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
May as well read this before you get started...
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Distributor Springs needed and some info [Re: pacifica] #1417491
04/09/13 11:28 PM
04/09/13 11:28 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Advancing at 600rpm is not good. I hope that's Dist RPM which would be 1200 crank RPM.
I remember the thread from before and that was one thing I recall mentioning that could not and should not happen.
Put something equal to garage door springs on it so it's not advancing at idle and set your initial and go from there.
Ace sometimes has micro springs that can be used.
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417492
04/10/13 01:05 PM
04/10/13 01:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Distributor Springs needed and some info [Re: moparrulzzz] #1417493
04/10/13 09:11 PM
04/10/13 09:11 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I went through this exercise over the winter. Everyone sells light springs. It depends what kind of curve you want.
I went through the trouble of refurbishing an old Sun 400 distributor machine. It was a huge help sorting through a bunch of different combinations.
My biggest problem is too much compression pressure, coupled with a heavier car, four speed and higher rear gears.
I needed a curve that starts at about 1500 RPM and peaks at 3000 RPM. The amount of mechanical advance will effect the peak. If you limit the mechanical advance by welding the slots, the peak will happen sooner, albeit, at a lower total timing.
I used a combination of springs I got from FBO. They are not exactly the same as stock by as long as they don't bind on the posts, they will work. I used one heavy spring and one light one from the set you can get from summit to service the newer style Mopar Performance distributors. FBO also sells a plate the mount on the pins of the weights. It has 3 sets of slots to limit the mechanical advance from 10 to 18 degrees. It also has holes to lock out the mechanical advance.
Normally the stock heavy spring has a slot to speed the advance up a bit at lower rpm. I find this type of spring doesn't work very well when you limit the mechanical advance. In my case I have mine limited to 14 degrees. If I used the slotted spring, it would use up the slot and never get into the spring.
Re: Distributor Springs needed and some info [Re: torkrules] #1417494
04/10/13 09:17 PM
04/10/13 09:17 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Actually, a member on here makes and sells the plate that limits the total timing as well. I don't recall his Moparts name but I have hi email. PM me if you want me to sent it to you.
Re: Distributor Springs needed and some info [Re: torkrules] #1417495
04/10/13 10:22 PM
04/10/13 10:22 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
This is why I never understood why people toss the heavy spring and replace it with a light one. You are actually slowing where the curve begins compared to stock, although total curve will come in faster. You either need to either toss the heavy slotted spring and run just one light spring or change both springs to a lighter spring. But people think the timing will bounce around/come in at idle. If it didn't with the slotted spring its not going to with just the lighter factory spring.
