BG Fuel regulator
#1417456
04/09/13 06:13 PM
04/09/13 06:13 PM
Posts: 1,142 Central New York
slippery440
Crybaby440
Crybaby440
Central New York
Put a new BG fuel regulator on the car and I can not get the pressure below 12 pounds. What started this problem was I had a fuel pump problem that the pump was running at full pressure and the regulator and gages were peged. I change the fuel pump and that was the main issue with the way to much pressure.Stuck relief valve. Question does the ball inside of the regulator seat against the fitting in main in port in the bottom of the regulator or against the inside tower part of the regulator? Its a 2 port BG tower style regulator. Yes I am running the motor when I am setting the pressure.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: BG Fuel regulator
[Re: pittsburghracer]
#1417458
04/09/13 07:42 PM
04/09/13 07:42 PM
slippery440
Crybaby440
Crybaby440
Central New York
The fuel pump is only a 140 gph and I can not believe it puts more than 15 to 20 pounds fuel pressure. The regulator is brand new and it cost $$$. I beleive you about the fuel spike because it happen to a race buddie of mine that put a 280 or bigger pump on his car and did the same thing that happened to you.He had a AREO?? regulator.
