factory push rods?? #1417294
04/09/13 01:10 PM
04/09/13 01:10 PM
canada
jp15 Offline OP
jp15  Offline OP
canada
what would be the most spring pressure I could safely run on stock 360ci push rods???
doing a cheap as I can build for my wifes car . then selling it after she plays for awhile.
Re: factory push rods?? [Re: jp15] #1417295
04/09/13 01:19 PM
04/09/13 01:19 PM
Locomotion Offline
Locomotion  Offline
Maybe no more than 300lbs open, but that's not the whole picture. It's the stamped rocker arms that usually have a pushrod punch through them. Lift and rpm are also a factor, especially if you plan to run it hard. It's difficult to gauge how well or long OEM stuff will hold up when you start start adding other performance stuff. But "the weakest link in the chain" will show itself eventually.
Re: factory push rods?? [Re: Locomotion] #1417296
04/09/13 01:29 PM
04/09/13 01:29 PM
canada
jp15 Offline OP
jp15  Offline OP
canada
Should have dug these out first..... the springs are open 366lbs @1.150"
won't be seeing any more than 6,500 rpm, hyd. cam
Re: factory push rods?? [Re: jp15] #1417297
04/09/13 10:29 PM
04/09/13 10:29 PM
Locomotion Offline
Locomotion  Offline
Well, I simply wouldn't even consider it. But I tend to be extra cautious. I've been running around those pressures on my race car with Crane & Harland Sharp rockers and .08?" wall pushrods! I believe OEM may be around .065"
There have been some discussions on OEM rockers. Hopefully someone will chime in who has had first-hand experience in this situation.
Re: factory push rods?? [Re: Locomotion] #1417298
04/10/13 06:39 AM
04/10/13 06:39 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The stamped steel rockers WILL fail at that pressure and r.p.m.
Not might........WILL.
I'd guess I got maybe 1000 miles on mine before the pushrod punched through.
The H.D. stamped rockers would be the cheapest Bandaid for you.
I have no experience with them , but was told that they are stronger.
I went right to Harland Sharps because I wasn't going to gamble on it happening again.
It was far less enjoyable as a V-7.
