"Rattle" In Transfer Case Handle Area #1417226
04/09/13 06:25 AM
04/09/13 06:25 AM
Q
qkRick Offline OP
qkRick  Offline OP
Q
Recently developed an absolutely maddening rattle coming from the transfer case lever area in my 97 Ram Cummins powered automatic trans truck. 267k mi. Problem most noticeable at highway speeds in 2wd high with lever in what always has been the normal position. If I move lever to the right just a bit the noise stops.Noise resumes after handle drifts back to left. Any help appreciated.
Thanks MoParts
Re: "Rattle" In Transfer Case Handle Area [Re: qkRick] #1417227
04/09/13 11:00 AM
04/09/13 11:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Beleive there is a bushing kit available for those. IIRC there may have even been a TSB for that issue.
Re: "Rattle" In Transfer Case Handle Area [Re: J_BODY] #1417228
04/09/13 11:48 AM
04/09/13 11:48 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I think you're right
http://dodgeram.info/tsb/1996/21-13-96.htm
Lots of "buzz" about it back in the day.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: "Rattle" In Transfer Case Handle Area [Re: 3hundred] #1417229
04/09/13 08:06 PM
04/09/13 08:06 PM
Q
qkRick Offline OP
qkRick  Offline OP
Q
Thanks People
MoParts Rocks
