Recently developed an absolutely maddening rattle coming from the transfer case lever area in my 97 Ram Cummins powered automatic trans truck. 267k mi. Problem most noticeable at highway speeds in 2wd high with lever in what always has been the normal position. If I move lever to the right just a bit the noise stops.Noise resumes after handle drifts back to left. Any help appreciated.
Thanks MoParts
