E85 and SS hose internal materilas you use?
#1417167
04/09/13 01:01 AM
04/09/13 01:01 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
I'm plumbing my new car for E85, I got in a hurry to finish the car so I reused some of the existing hose on the car, it has ben around six years since it was last raced is what I was told by the former owner. It was ran on straight methanol so I assumed ( ) all the SS lines where TFE,Teflon, lined but it turns out one of them was neopreme lined, it leaks I replaced it with a new neopreme line that I had the fittings and hose to make it run in stock I need to order some more TFE fittings for the SS teflon lined hoses I have in stock,I will probally replace all of the SS hoses in the fuel system unless I hear that you can use the neopreme with E85 okay Are any of you using E85 using neopreme hoses with good luck or not
Re: E85 and SS hose internal materilas you use?
[Re: Cab_Burge]
#1417168
04/09/13 01:46 AM
04/09/13 01:46 AM
Posts: 202 TN Hoosier
jb500
TN Hoosier
The National Renewable Energy Laboratory says it is ok. Ethanol compatability As long as it is not natural rubber lined you should be good.
[Re: Cab_Burge]
#1417169
04/09/13 01:54 AM
04/09/13 01:54 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
When you find suitable hose, please share the brand, stock name and how you can positively identify the stuff. I have seen a lot of hose offered for sale and very little of it is the Teflon lined that is impervious to fuel of all kinds. Seems that many vendors are trying to dump their old stock.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1417170
04/09/13 10:03 AM
04/09/13 10:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Most hose now days has a liner in it... 2 liners are used on a normal basis... the Teflon and Viton... both are impervious to most chemicals and all fuels... to spot it you can look at the end of the hose... you will see a different color on the inner(usually a darker color)but you will see a distinct line where the two products are bonded... for regular fuel hose.. the injected hose it will say "EFI" on the hose.. this will have the liner...EFI hose also has a higher burst rating... its sorta hard to find the old carb hose now days(which was NON lined hose)
[Re: MR_P_BODY]
#1417171
04/10/13 12:08 AM
04/10/13 12:08 AM
Cab_Burge
Mike,this is the hose that was leaking, it is old like me also It looks like it has two layers in it like you describe but the inner layer is the same color as the outer is , does this look like what you've seen before ? I replaced it with some newer rubber lined SS hose and it doesn't leak, yet I will end up replacing that and all the rest of the hose in the system with either aluminum hard lines and TFE lined hoses and fittings as soon as I can
[Re: Swedcharger67]
#1417178
04/10/13 04:40 PM
04/10/13 04:40 PM
MR_P_BODY
Oops ive been useing alu fuel line for several years now.
And I've just bought alu fuel lines to install for my E85 street engine. Research papers say E85 has very little impact on aluminium, so I don't expect any problems.
Its not the E-85... its the water it absorbs... water on alum will corrode ... even the coated alum line due to the fact that when you bend the line you crack the coating which exposes the alum
[Re: Cab_Burge]
#1417179
04/11/13 08:25 AM
04/11/13 08:25 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
We use teflon lined SS from Aeroquip.We drain the aluminium fuel cell after every race and run some gas with top oil through the fuel system if the cars is going to sit for awhile.The issue we see is that the aluminium fittings tend to oxidize from E-85 or alcohol.
Thanks, Bob I'll have to do that also, I've already seen the E85 atack the aircraft quality thread lube I used on the fittings before finding the hose and pump leaks, no usage other than filling the sytem to check for leaks What top oil do you like Bob?
Marvel,STP or most any brand you can get,mix it with some gas.Menthonal and ethynol as well as some octane,oxygenated fuel gather moisture and create the oxidizing to the metals.Darryal Franks bought some 116 oxygenated fuel and left it in the car over winter at our shop,in the spring it looked like solid white crystals formed in the carb and fuel system.
