advice on 360 stroker build #141700
10/26/08 03:34 PM
10/26/08 03:34 PM
Anonymous OP
Anonymous OP
I have a 1970 Duster--no motor. I want to build a stroker. Where can I get the best parts and deals?
Re: advice on 360 stroker build #141701
10/26/08 04:46 PM
10/26/08 04:46 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Dram is a member here and has quoted me some very competative prices on stroker stuff. Every time I get the money together some thing happens and have to spend my money on some house hold something or nother. His prices are almost the same as summit or jegs but you get someone who knows mopars who can give you some good advice and work with you if you have a problem so it would be worth while even if it was a couple bucks more
Re: advice on 360 stroker build [Re: HotRodDave] #141702
10/26/08 05:26 PM
10/26/08 05:26 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
give Dram a call Dan is a hellofa nice guy to work with.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
