Page 2 of 3 1 2 3
Re: 833 troubles [Re: RapidRobert] #1416852
04/09/13 08:48 AM
04/09/13 08:48 AM
Russ H. Offline
Russ H.  Offline
Where are your jack stands placed? Are they supporting the rear axle?
Re: 833 troubles [Re: Russ H.] #1416853
04/09/13 09:25 AM
04/09/13 09:25 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
After re-reading your original lockup symptoms, it appears that they have disappeared after pulling the driveshaft. That sure tells me that the third member and/or the shaft is where I'd be focussing my efforts.
This is the land of the free because of the brave
Re: 833 troubles [Re: rbstroker] #1416854
04/09/13 09:27 AM
04/09/13 09:27 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
You say Aluminum carrier?
Re: 833 troubles [Re: rbstroker] #1416855
04/09/13 09:36 AM
04/09/13 09:36 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Could the slip yoke be pushing against the output shaft (bottoming out)? with the wheels hanging?
Support the rear with the weight of the car (jack stands under the axle tubes (not the frame).
Re: 833 troubles [Re: jcc] #1416856
04/09/13 10:11 AM
04/09/13 10:11 AM
Sugarloaf, PA. USA
JamiePasson Offline
JamiePasson  Offline
Sugarloaf, PA. USA
John,
I spent a fair amount of time last night reflecting on this situation. I am coming up blank. If it was the trans, it would seem to me that it would still do it even with the driveshaft off it. The other possibility would be the yoke in the rear bushing, BUT you would have really struggled getting the yoke out of the trans. As I said on the phone, even thought the trans is way out of warranty, I will be happy to look at it for you to try to determine if there is an issue in it. Keep me posted.
Thanks,
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: 833 troubles [Re: jcc] #1416857
04/09/13 10:15 AM
04/09/13 10:15 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Tried to get the car out this past weekend but it went downhill fast.
Here are I believe are the pertinent facts:
1. Small blk with Passon Alum 4 speed 6? years old, , 2000 trouble free miles, has sure grip, OEM tapered axles.
2. Car has seen no miles in 4 years
3. When car sits on jack stands, rear wheels and DS turn easy by hand when in neutral both ways, engine off.
4. Engine starts fine, pushing clutch in tranny goes into any gear fine.
5. When letting clutch out when in 1st gear on the jack stands, unless revs are brought up to say 2500rpm engine dies, and wheels still turn very hard/slow.
6. Pushing clutch in with trans still in gear and with wheels still turning, causes wheels to immediately to lock up.
7. Above is the same in 2nd but much harder to get wheels to turn, reverse the same, can't get wheels to turn without killing motor in 3rd or 4th.
8. I can get trans side cover shift levers into all normal? positions from below
Nothing indicates to me clutch/pressure is stuck.
Not sure if 8.75 could lock itself up. Everything goes south with trans in gear?
I'm at a loss, and am trying to eliminate as much as possible before yanking trans.
I have called Jamie and we are scratching our heads.
Any ideas?
After re-reading this again and again, unless I'm still missing something, it seems to me that one of your main drive gears in the trans is frozen to the output shaft.
With the car on jack stands and the drive shaft out, put the trans in neutral. Go under the car and see if you can turn the output shaft of the trans.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 833 troubles [Re: 68LAR] #1416858
04/09/13 03:13 PM
04/09/13 03:13 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Thanks again guys for all your help.
1. Carrier is MP alum 742
2. When problem first was noticed wheels were all on the ground, when raised, the rear jack stands are under the housing near the leafs, ie not hanging, but at ride height.
3. I will try tonight with a helper to hand turn a spare yoke with clutch depressed.
4. yoke bottoming does not seem likely
5. Original yoke slipped out when dropping DS with no issues
6. I don't know enough about 833 internals to reply on whether a gear has frozen to a shaft.
We will try again tonight.
Re: 833 troubles [Re: jcc] #1416859
04/09/13 04:11 PM
04/09/13 04:11 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
This will prove nothing. Try turning the output shaft with the transmission in neutral and the clutch pedal engaged (foot off of pedal). If it doesn't turn or is hard turning, then one of the main drive gears is too tight of the output shaft.
Re: 833 troubles [Re: 68LAR] #1416860
04/09/13 04:19 PM
04/09/13 04:19 PM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
Either that or the cluster gear is froze onto the shaft...
Re: 833 troubles [Re: Cuda340] #1416861
04/09/13 11:09 PM
04/09/13 11:09 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
So tonight i have a helper:
1. I verified the same problem as discussed before, no differences.
2. I pulled DS, rear yoke turns fine, wheels spin freely car on jack stands on housing.
3. Engine off in nuetral tranny clutch out No DS, tranny yoke spins free
4. Engine off in 1st, No DS, clutch depressed, tranny yoke spins free
5. Engine running, no DS, letting clutch out in 1st, no bog, tranny yoke spins free, and stops pretty quick when depressing clutch
Unless tranny needs a load to lock up, the above points to the rear end?
I might take a day off on this. Could a brake somehow decide to always drag under load? The rear end when I let out the clutch looks kinda of "grabby" before its starts to turn and then engine dies unless revs are way up. It has tapered axles and maybe I should pull the drums, to see if a mud dapper wasp made a nest, or something. Not sure which is more work or more certain, install another complete housing/3rd member w/brakes I have laying around and test, or yank the drums and then the carrier and keep hunting the problem. Regardless the Alum 742 has to go back in eventually.
Jamie if you see this latest post let me know, I will be contacting you regardless when something is known for certain.
Re: 833 troubles [Re: jcc] #1416862
04/10/13 03:11 AM
04/10/13 03:11 AM
Do you have another pumpkin you could toss in, that's what I'd do
Re: 833 troubles [Re: jcc] #1416863
04/10/13 09:58 AM
04/10/13 09:58 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Not really.... What happens if you put the transmission in 2nd or 3rd gear with no DS, engine running, clutch out?
Just trying to help. Example: If 1st gear is the "tight" gear on the main shaft, then it would function properly. If you put the trans. in another gear, then it would act like it is in two gears at the same time and you would have the symptoms/problems you describe.
Re: 833 troubles [Re: Russ H.] #1416864
04/10/13 10:30 AM
04/10/13 10:30 AM
Russ H. Offline
Russ H.  Offline
Maybe a stupid question but is your emergency brake fully released??
The way I see it, If all was well when last used and lube was not drained, Manual transmissions and 3rd members normally do not deteriorate from sitting. My money is still on something in the brake system. Try running it with the rear drums removed.
Re: 833 troubles [Re: 68LAR] #1416865
04/10/13 11:12 AM
04/10/13 11:12 AM
pa.
dan9 Offline
dan9  Offline
pa.
That's what I'm thinking too. Sounds like it is stuck in 2 gears.
Re: 833 troubles [Re: jcc] #1416866
04/10/13 11:16 AM
04/10/13 11:16 AM
pa.
dan9 Offline
dan9  Offline
pa.
Maybe just the shift linkage. I'd disconnect them and move the levers by hand and try it.
Re: 833 troubles [Re: Russ H.] #1416867
04/10/13 11:26 AM
04/10/13 11:26 AM
JCC please make some progress with this
Re: 833 troubles [Re: jcc] #1416868
04/10/13 12:15 PM
04/10/13 12:15 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Do you have "tapered axles" or "tapered bearings" in the rear?
Sure-grips require special length tapered (keyed) axles.
In other words, if you swapped a sure-grip into a pre '65 rear originally equipped with an open differential, you will have major problems.
Supposedly axle lengths were standardized in 1964, but I have never been able to confirm that.
Re: 833 troubles [Re: Russ H.] #1416869
04/10/13 12:38 PM
04/10/13 12:38 PM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
If you run with the rear drums removed be sure and not hit the brake petal.
Re: 833 troubles [Re: mopfried] #1416870
04/10/13 01:50 PM
04/10/13 01:50 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
On the first go round, were the drums hot after the sticking wheels incident? It would seem that just prior to putting car in gear with it up in the air, you would depress the brake pedal to ensure that a clean shift could occur. At that point, if your shoes are not returning properly, you would see the problem you describe. My 68 Charger did that and it was the most confounding thing. I would apply the brakes and they would stick. It would bleed down but it tooks a few minutes before the shoes would return and the wheels turned freely. I would guess it is something like that.
Re: 833 troubles [Re: RapidRobert] #1416871
04/10/13 03:02 PM
04/10/13 03:02 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
ALL suggestions when diagnosed properly should eventually lead to the problem. After eliminating, what's left is the problem. Not to be sarcastic or insulting, but do you know how transmissions, rear differentials and brakes work? I mean really work? What turns, what's engaged, etc? Just trying to help....
Page 2 of 3 1 2 3
