Should I add more R-12 freon...or is my A/C ok?
#1416795
04/08/13 03:18 PM
04/08/13 03:18 PM
Posts: 77 Louisiana
rnch
Louisiana
I added one can of R-12 to my new-to-me '85 ram's A/C yesterday.
The low side is 25.
A/C center vent temp is 42 degrees.
Outside temperature 75 degrees, humidity 50 percent.
Waddyathunk?
Re: Should I add more R-12 freon...or is my A/C ok?
[Re: rnch]
#1416796
04/08/13 04:41 PM
04/08/13 04:41 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Is the sight glass clear?
[Re: John_Kunkel]
#1416797
04/08/13 05:54 PM
04/08/13 05:54 PM
Posts: 77 Louisiana
rnch
Louisiana
94% of the time; just a little bit of "foam" when the compressor cycles on. Then a tiny bit every now and then.
[Re: rnch]
#1416798
04/08/13 08:23 PM
04/08/13 08:23 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
83 FSM shows 70F: 18-30psi Low side Discharge air temp: 38-50
80F: 20-35 psi Discharge temp: 42-54
I say run it
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1416799
04/08/13 09:23 PM
04/08/13 09:23 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
If it's very low, the compressor will cycle on and off quickly. When you have a decent charge, the compressor should kick in and stay engaged for a while.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: herkamer]
#1416800
04/09/13 11:54 AM
04/09/13 11:54 AM
Posts: 77 Louisiana
rnch
Louisiana
I say run it
I think I will!
IMO there is no such thing a "TOO Cold air conditioner" here in Hot & Humid New Orleans, LA, USA.
But, having said this, I'm not going to waste most of another can of R-12 to get another 2 or 3 degrees colder vent temperature.
Also, I am concerned about putting anymore pressure on/in those factory hoses, condensor and evaporator than I have to.
[Re: herkamer]
#1416802
04/10/13 04:18 PM
04/10/13 04:18 PM
Posts: 77 Louisiana
rnch
Louisiana
I drove the truck yesterday and today. It's in the low 80's today here in New Orleans, very humid also. The truck's A/C is more than adequate. 'course the True Test will be late August/early September, when the Heat AND Humidity are in the mid/high 90's.
