Page 3 of 3 1 2 3
Re: New Race Wheels and Tires [Re: LAR_414] #1416659
04/10/13 06:50 PM
04/10/13 06:50 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I REALLY like the way the car looks!! I think the stance is perfect.I just bought new Centerlines also.. replaced the Auto Drags with Qualifiers,as I'm going to go back on the street.I was going to lower my car,but after seeing yours,mine is staying as is.
Super nice car,I know you are proud of it.
Nautilus Racing-
Re: New Race Wheels and Tires [Re: LAR_414] #1416660
04/10/13 11:01 PM
04/10/13 11:01 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
Thanks all!
The front tires are about 27.5 to 28" tall. The rears are 29.5 to 30".
The wheels are 4" wide and I have Wilwood brakes on the front. So the wheels are out a bit from stock.
I have the fenders trimmed for these tall front tires.
I actually like to fill the wheelwells up as much as possible. That's how I get the stance that I like. Show as little space between the tire and the body, without having a low rider!
The tall fronts allow me to have great ground clearance on the street and keep my T-bars at a stock setting, for great travel and alignment.
Thanks again.
Any chance of some pics of how you trimmed the fenders ? and again, really like how the car sits up like that.
Great looking car
Re: New Race Wheels and Tires [Re: 2734bbl] #1416661
04/10/13 11:39 PM
04/10/13 11:39 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Wheels are way way cool!
But...I'd get that rear down about 2"
Always thought this car was a perfect example of street and strip. The gas mileage is the icing on the cake!
Re: New Race Wheels and Tires [Re: LAR_414] #1416662
04/11/13 05:05 AM
04/11/13 05:05 AM
Illinois
354valiant Offline
354valiant  Offline
Illinois
Lar_414, The look of your Dart is awesome very sharp, but I especially like the super clean and simple look of your small block with the cross ram! Where did you get your air cleaners? They round out the nostalgic look to the engine that make it look factory installed, too bad this package was never offered. Cool car, Thanks Brian
Re: New Race Wheels and Tires [Re: LAR_414] #1416663
04/11/13 09:34 AM
04/11/13 09:34 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Thanks all!
Thanks again.
personal preference, I'd like the front tires about 26" tall and maybe the back end 1-2" lower
2017 Grand Cherokee Overland
Re: New Race Wheels and Tires [Re: patrick] #1416664
04/11/13 10:42 AM
04/11/13 10:42 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
Thanks again all.
The air bells are made by me. I bought some air bells from somewhere and went to home depot for the rest. Works great. I even have some cloth covers for the top when I take a long drive or it's dusty out.
My fenders are about 20+ years old and fiberglass. So I've cut the front edge and the lip a bit. It can be done with metal fenders too.
I've got multiple mounting positions for the rear springs. It's set at the highest setting right now. I've run it lower (about 1") and it doesn't hook as well. The IC is better at this position.
I've run the front lower too, but there is no real need, as there is enough rake to the stance right now.
My street tires a about 1" shorter than these tires.
Either way, right now, it launches great at the track. I Dump the clutch at about 6,000rpm and it spins the tires for about the first 15-20 feet. Doesn't bog down the motor, and it's a controlled spin.
Other setups make the tires bounce, or lift and release, or not recover the wheel spin quick enough.
Also, I drive this car a TON on the street. I take it pretty much anywhere. Speedbumps and un even pavement are not friendly when it sits too low. Not so much for the oil pan, but for the exhaust. It's tucked up tight to the floorboards, but I've got 3.5" SS pipes from the collectors to the muffs.
This is no pure racecar that doesn't need a full exhaust and can sit super low to the ground.
Plus I kinda like the old pro stock / SS/A look from the 70's. Not everything has to sit super low. But I see some of your points out there. I've had it lower and it looks good, but I like where it's at now.....may change my mind next week, you never know!
Page 3 of 3 1 2 3
