hemi 4 speed #1416357
04/07/13 10:34 PM
04/07/13 10:34 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
How much stronger is an 18 spline hemi 4 speed than the regular 23 spline 4 speed.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: hemi 4 speed [Re: 73cuda340] #1416358
04/07/13 11:11 PM
04/07/13 11:11 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Quite a bit actually, BUT I do not see many problems with fine splines until someone puts slicks on and an aggressive clutch in. I then see the speed gears starting to weld to the output shaft, the hemi box has bushings in that area. Keep good bearings and clean lube in a fine spline and it will live.
Re: hemi 4 speed [Re: 4406bbl] #1416359
04/08/13 08:33 AM
04/08/13 08:33 AM
indy
70moparmike Offline
70moparmike  Offline
indy
is a centerforce dual friction too aggesive?? doing a 500 stroker, will it live?
Re: hemi 4 speed [Re: 70moparmike] #1416360
04/08/13 11:14 AM
04/08/13 11:14 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
NO and Yes. This is what I use. 'Have been for several years.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: hemi 4 speed [Re: 68LAR] #1416361
04/08/13 06:58 PM
04/08/13 06:58 PM
AZ.
696pack Offline
696pack  Offline
AZ.
I would steer away from a center force, I have had and seen nothing but trouble with them in the past for hipo use.
Re: hemi 4 speed [Re: 696pack] #1416362
04/09/13 12:35 AM
04/09/13 12:35 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I assume this is your opinion. Opinions are like as...., everybody's got one. I'm speaking form personal experience not what I've heard... CFDF works for me and has for several years. Best bang for the buck. This is my opinion and my .
Re: hemi 4 speed [Re: 68LAR] #1416363
04/09/13 01:41 AM
04/09/13 01:41 AM
AZ.
696pack Offline
696pack  Offline
AZ.
I assume this is your opinion . Opinions are like as...., everybody's got one. I'm speaking form personal experience not what I've heard... CFDF works for me and has for several years. Best bang for the buck. This is my opinion and my .
Not just hearsay, from my own experience and yes it is my opinion.
Re: hemi 4 speed [Re: 68LAR] #1416364
04/09/13 05:21 AM
04/09/13 05:21 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I've had a few of them and not a problem out of them at all.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
