1963 dodge max wedge vehicle no. decode? #141634
10/26/08 12:47 PM
10/26/08 12:47 PM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
Can anyone help me as to where you can decode a 1963 dodge vehicle no. that is on the pillar on the drivers side. My car is supposed to be a 426 max wedge car, it hass no fender tag. Thanks Tim
Re: 1963 dodge max wedge vehicle no. decode? [Re: ts70rt] #141635
10/26/08 12:54 PM
10/26/08 12:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure post the VIN number
Re: 1963 dodge max wedge vehicle no. decode? [Re: ScottSmith_Harms] #141636
10/26/08 01:52 PM
10/26/08 01:52 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Three are a few guys on here who are quite knowledgable on the early max wedge cars. John Kunkel is one of them.
Re: 1963 dodge max wedge vehicle no. decode? [Re: ts70rt] #141637
10/26/08 07:30 PM
10/26/08 07:30 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
There are a lot of max wedge only features, brake line routing, wiring harness routing, exhaust hanger brackets, the vin info identifies the build plant...the list goes on. Other members here will chime in.
Re: 1963 dodge max wedge vehicle no. decode? [Re: MO_PA] #141638
10/26/08 07:54 PM
10/26/08 07:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have the 63 Dodge book by Darrell Davis on the 63 Dodge Max Wedge cars which has all the vin's in it. You can post it or pm it to me and I can check it. Ron
Re: 1963 dodge max wedge vehicle no. decode? [Re: MO_PA] #141639
10/26/08 08:49 PM
10/26/08 08:49 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I think an easy one is if the ballast resistor is mounted in another position on the firewall to clear the rear air cleaner.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: 1963 dodge max wedge vehicle no. decode? [Re: pishta] #141640
10/28/08 05:18 PM
10/28/08 05:18 PM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
Ballast resistor stayed. Voltage regulator moved.
Re: 1963 dodge max wedge vehicle no. decode? [Re: 383man] #141641
10/28/08 07:23 PM
10/28/08 07:23 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
VIN is the only way to identify a real max wedge car, everything else can be faked.
