throttle cable angle #1416122
04/07/13 07:07 PM
04/07/13 07:07 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
How does the angle at which the throttle cable is attached to the carburetor effect responsiveness? If the cable is pulling straight back vs. at a downward angle how does this effect it? I'm looking at trying to slow my reaction times down. Made some changes over the winter and the car has picked up 1/2 tenth in 60' times, but now I'm consistently .030 - .050 red. I've tried lower launch rpm and messed with tire pressure both front and rear, but haven't stumbled across the right combo yet, so I was looking at changing the throttle cable angle. Any input is appreciated.
Re: throttle cable angle [Re: DusterKid] #1416123
04/07/13 08:47 PM
04/07/13 08:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
none as long as it's not binding. you can mess with timing. how much does your car weigh? you may be anticipating.
Re: throttle cable angle [Re: DusterKid] #1416124
04/08/13 10:19 AM
04/08/13 10:19 AM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Dusterkid,
You my want to try using a blinder to block the top 2 yellows. This will delay your reaction time.
Larry
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
