89 Ram has no acceleration! #1415897
04/07/13 11:53 AM
04/07/13 11:53 AM
P.E.I. eastern Canada
N
newportrider Offline OP
N
My 89 Ram 318 fuelie auto, acted up around Christmas, where it will not accelerate. It starts and idles fine, but if you try to rev it up will not accept throttle, bogs, sometimes back fires. I replaced the fuel filter, and it has half tank of fuel. I started it this morn after sitting since New Years and it started with out a hitch, but will not rev up. Is it a throttle body/electical or what. Spring is here and I need a truck, any Ideas?
Re: 89 Ram has no acceleration! [Re: newportrider] #1415898
04/07/13 01:00 PM
04/07/13 01:00 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
First, start by checking for stored codes. Key on-off-on-off-on within 10 seconds. See if anything comes up. Next would be to reset any soft codes that are not stored by disconnecting the battery for 30 minutes. Next I would check to see if the injectors have a good spray pattern with a timing light. Start there and see what you can come up with. Despite everyone saying to go to a carb, I've found these aren't that hard to work on.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 89 Ram has no acceleration! [Re: herkamer] #1415899
04/07/13 02:31 PM
04/07/13 02:31 PM
N
N
I know little to nothing about fuel injection. How would you reset codes?
Re: 89 Ram has no acceleration! [Re: newportrider] #1415900
04/07/13 03:38 PM
04/07/13 03:38 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
proper sequence for checking codes is on off on off on off on without cranking starting, watch for the blinking series. To reset you simply dissconect the battery for about 30 seconds. A FSM is invaluable in this case..
I am truckless..
Re: 89 Ram has no acceleration! [Re: 340SHORTY] #1415901
04/07/13 03:56 PM
04/07/13 03:56 PM
N
N
I had the battery out last night to move another old truck of mine,86 carbed, put it back in 2hrs ago no change still acting the same.
Re: 89 Ram has no acceleration! [Re: newportrider] #1415902
04/07/13 04:48 PM
04/07/13 04:48 PM
St. John's Newfoundland
440newport Online content
440newport  Online Content
Mine acted the same way before and it turned out to be a corroded cap and rotor, so check those first. Also sounds like it could be the map sensor. Turn the key on-off-on-off-on and watch the check engine light for the codes if there are any.
Re: 89 Ram has no acceleration! [Re: 440newport] #1415903
04/07/13 05:24 PM
04/07/13 05:24 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
just resetting the codes isnt going to fix the troubles.
I am truckless..
Re: 89 Ram has no acceleration! [Re: 340SHORTY] #1415904
04/07/13 05:38 PM
04/07/13 05:38 PM
N
N
Message center is flashing 5 times. I can't tell if there is long or short flashes all look the same to me!
Re: 89 Ram has no acceleration! [Re: newportrider] #1415905
04/07/13 07:36 PM
04/07/13 07:36 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Be sure the fuel pressure is around 14.5. If its 8 or 10 or similar, that's your problem. very common.
Re: 89 Ram has no acceleration! [Re: jerseybud] #1415906
04/07/13 09:37 PM
04/07/13 09:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You need to learn how to read the flashes..
I am truckless..
Re: 89 Ram has no acceleration! [Re: 340SHORTY] #1415907
04/07/13 10:29 PM
04/07/13 10:29 PM
N
N
Yeeah
Re: 89 Ram has no acceleration! [Re: newportrider] #1415908
04/07/13 11:48 PM
04/07/13 11:48 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Flashes are read as a blink of the check engine light in the message center, and always 2 numbers. No zero and none start higher than 6. It will have a short pause between blinks, then long pause between digits and codes. Long and short is relative, maybe 1/2 sec difference. You should have a code 12 since the battery has been out within the 50 last key ons, and it always ends with 55. Mine always has 37 which is not a big deal, has to do with the A/T.
I also had a wasted cap and rotor when I first bought it and it would barely run. Good place to start looking.
Matt
69 Dart Swinger 340
and even more
Re: 89 Ram has no acceleration! [Re: herkamer] #1415909
04/08/13 07:16 AM
04/08/13 07:16 AM
N
N
Thanks for the info. I'll recheck the codes this evening after work. The cap button and wires were replaced in October, but it could be bad. The out door garage work doesn't appeal to me this time of year.
Re: 89 Ram has no acceleration! [Re: newportrider] #1415910
04/08/13 09:23 AM
04/08/13 09:23 AM
scratchnfotraction Offline
make sure you did not cross 3-5 plug wires
it will run but not run very well.
Re: 89 Ram has no acceleration! [Re: scratchnfotraction] #1415911
04/08/13 02:55 PM
04/08/13 02:55 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Are you hearing any hissing from the exhaust when the engine is running? On my '90 Dakota, the catalytic converter "brick" inside the case cracked, and pieces went down inside the muffler and plugged the muffler. Does the converter or muffler rattle when you bang on it with a rubber mallet? I had very weak power until I mashed the throttle one day out of frustration, and BANG, blew a hole in the side of the muffler... then the power came back.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 89 Ram has no acceleration! [Re: GO_Fish] #1415912
04/08/13 04:27 PM
04/08/13 04:27 PM
N
N
Exhaust is clear, new muffler installed last Oct and converter gutted by previous owner. going out to see if I can interpet the code flashes.
Re: 89 Ram has no acceleration! [Re: newportrider] #1415913
04/08/13 06:20 PM
04/08/13 06:20 PM
N
N
Well I tried reading the codes. First set 3 flashes: 12 or 21 ? second set: four flashes: 13 or 22 or 31? followed by two sets of 5. Sorry but I couldn't tell short from long flashes but I did notice the pause between codes. Took me 6 tries!LOL TIA
Re: 89 Ram has no acceleration! [Re: scratchnfotraction] #1415914
04/08/13 08:09 PM
04/08/13 08:09 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
especially if all your problem started after the replacing the wires!!
Re: 89 Ram has no acceleration! [Re: newportrider] #1415915
04/08/13 08:11 PM
04/08/13 08:11 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
There are no long or short flashes, just long or short pauses.
12 - PCM Power loss within 50 last key ons. To be expected since the battery has been out
13 - MAP sensor problem - Controls most fueling, that would certainly be something to look at
22 - Coolant temp too high or low
31 - Problem with canister purge solenoid circuit
Based on your description I get 34
34 - Open/short in speed control vacuum or vent solenoid circuits
55 - End of codes
Almost everyone in the world has a cell phone with video camera. Maybe take a video?
Matt
69 Dart Swinger 340
and even more
Re: 89 Ram has no acceleration! [Re: jerseybud] #1415916
04/08/13 08:20 PM
04/08/13 08:20 PM
Lehigh Acres, Florida
rickstershemi Offline
^^^^THIS.....have you replaced the fuel filter...?????
Rickster
