Will "Metal_Fill" body filler stand up to heat?
#1415849
04/07/13 10:49 AM
04/07/13 10:49 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
I have a set of old M/T valve covers. Like the ones in the picture. I would like to get rid of the fins and M/T, and smooth them out to match the raised "inscription pad" at the bottom, for a custom look. I had thought about having them machined down but that would go into the recess underneath the raised pad.
Is there something I can fill in the area between the fins with? Too deep to want to use normal body filler obviously. I found "Metal Fill" supposedly cures hard enough to drill and tap, Bondo also has a metal filler. I am just wondering if whatever polymer base is in them will stand up to the heat that valve covers will being seeing on a street driven car.
Thanks all.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Will "Metal_Fill" body filler stand up to heat?
[Re: azblackhemi]
#1415851
04/07/13 12:15 PM
04/07/13 12:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
THis is what we used to use the the Navy for repair aluminum castings regardless. http://www.devcon.com/products/products.cfm?brand=Devcon&family=Aluminum%20Putty%20%28F%29Does NOT look like aluminum when cured and it will not polish out. Dunno if you can powder coat over it either. According to the MSDS information "Heating resin above 300 F in the presence of air may cause slow oxidative decomposition." so it may not be best.
[Re: elitecustombody]
#1415853
04/08/13 02:19 PM
04/08/13 02:19 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I'd just sell them and buy a set that are smooth.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
