6 pack rods, max rpm
#1415701
04/07/13 01:47 AM
04/07/13 01:47 AM
Posts: 302 Middle of the US
Verga
Middle of the US
What is the max rpm that 6 pack rods should be turned?
EDIT...max safe RPM w/ KB hyper pistons...
I know its not 1980, but it is what it is.
Motor turns 6500 with ease, just wondering what the safe rpm is for the rods.
"Im supercharged, might explode in your face"
Re: 6 pack rods, max rpm
[Re: Verga]
#1415703
04/07/13 09:11 AM
04/07/13 09:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Why base your engine rpm on a set of old heavy rods... buy a new set of H-beams and let the dyno tell you what the max rpm will be... I would buy a set of chevy rods to get the small in size and the chevy rods are cheaper the mopar
[Re: Verga]
#1415704
04/07/13 10:28 AM
04/07/13 10:28 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
6200rpm with a stock weight piston, (3.75 stroke) 6800 rpm with the same stroke and a really light stroker piston like in a 451 /400 lowdeck. I built a 440 with them back in 1975, and it is still running today after seeing bracket racing duty in two cars for four seasons. The only reason to use them now days is if they are already rebuilt and you know their history, and it is a budget project that will stay within those rpm ranges.
[Re: RUNCHARGER]
#1415707
04/07/13 03:37 PM
04/07/13 03:37 PM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
Ran those rods in my cuda from 1988-2000. They were coupled w/heavy TRW 2295 pistons. I shifted at 6500 and went thru the traps at 6800. Used off the shelf ARP rod bolts that were sold at Summit back in 1988. If the cylinder wall hadn't split no telling how much longer I could have ran them. That engine probably had 400-500 passes on it w/o any tear down.
Ok
[Re: CHAPPER]
#1415711
04/08/13 11:20 PM
04/08/13 11:20 PM
cudatom
Massillon, Ohio
Yeah best for me w/the combo(DC .590 cam)was 10.82. Car w/me was 3400lbs. Rods never failed. Had the car painted and the body shop moved the 1/2 aluminum fuel line a bit to do the engine compartment. Car was running slower than usual after getting it back. Everything seemed right good oil pressure, fuel pressure was up when bang, split cylinder and then hydro locked the engine. Took a large chunk out of the brock and turned 3 rods into pretzels. After I tore everything down and went to put braided line in I found the kinked fuel line. Car ran lean and that was it. That combo was deadly consistent. Never varied by more than .002-.003 regardless of temp.
Ok
[Re: A/MP]
#1415713
04/09/13 02:34 PM
04/09/13 02:34 PM
Posts: 903 Saskatchewan, Canada
cudabin
I am re-using my original six pack rods on my new build, but I had them magnaflux/crack checked, then installed ARP 2000 rod bolts, and had them resized on the bottom end. With the old heavy TRW six pack pistons, I used to shift at 6,500 all the time and had no issues. This time I am using custom Diamond pistons and tool steel pins that weigh 379 grams less each... I will sleep soundly knowing that the new Mr Six Pack cam likes to be shifted around 6,000 -6,200 rpm and the rev limiter on the new Rev-n-nator box will be set at 6,500 rpm. Lighter pistons, good bolts, and under 6,500 rpm they should be fine! Good luck with it. Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
